Search Results (Searched for: gs swing arm)
Replied by SeattleKZ on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
18 Jun 2013 01:53
Yeah, I'm in Seattle. Thanks for the info. I'm thinking of putting a ZRX swing arm on my kz900 but can't afford to do the whole thing right now so I'm gathering info and looking for parts. I haven't found anybody local that's done this yet. Pretty clean upgrade that shares the lineage of the Z bikes.
Replied by tk11b40 on topic 1975 KZ 900 , ZRX Swingarm, 89 GSXR front end
18 Jun 2013 00:53
Rear shocks:
fully extended 13.5" center to center eye to eye.
Yes they are 17 inch wheels, Front from an early 90's GSXR, rear from a 99 ZRX 1100.
Thank you for the compliment, you appear to be from Seattle, I was living in Wenatchee until 2007.
Replied by Hollywoodmx on topic HollywoodMX's Drouin Supercharged 77 KZ1000!!
17 Jun 2013 21:48 - 17 Jun 2013 21:51
So I'm STILL messing with the paint... Found some more small imperfections. I really just need to leave things alone... lol.
I will clear it tomorrow hopefully. I really need to move forward on this bike and it all starts with a rolling chassis.
I needed to close the gap in the swing arm pivot. It's about 1 mm off so I made some hi-tech custom spacers, it was slightly dangerous! Ghetto fab! Zed eat your heart out.. :silly: :whistle: :woohoo:
Also lightly polished the rear axle pin and bolt. And got my custom boots made to my foot specs!
Attachment 20130616_161705.jpg not found
Attachment 20130616_161745.jpg not found
Attachment 20130616_162015.jpg not found
Attachment 20130616_162027.jpg not found
Attachment 20130616_165916.jpg not found
Attachment 20130616_165922.jpg not found
Attachment 20130612_0744450.jpg not found
Replied by Haybus on topic 76 KZ900 LTD Streetfighter build
15 Jun 2013 11:51
I had the engine in when I first attached the swingarm. I took it out to weld the shock mounts. I'm not that good at welding upside down, or things I can't see very well.
Alan
Alan
15 Jun 2013 10:48
Great looking bike you have there...
Couple questions
what's length on the rear shocks?
are those 17" wheels?
Couple questions
You have begun your affair with your KZ by making a classic & common mistake - breaking fasteners. This problem is extremely simple to avoid; no fastener should ever be broken when being removed. Breaking the carb holder fasteners is one of the most common mistakes, but there are others that will break too if brute force rather than chemical assistance is used. As you are learning the hard way dealing with broken fasteners is no fun at all.
Please consider the following; it's a shame you hadn't read it before applying too much force to the screws, but it can save you headaches in the future.
TOOLS
Buy a can of Kroil penetrating oil and use it to soak stubborn fasteners for a couple days before trying to loosen them. Remember, the original screws and bolts were installed on your bike when Jimmy Carter was President, so many of them may be hard to remove. Kroil can be bought online, at guns shows, and at some other venues. This stuff has saved me MUCH heartache on fasteners that hadn't been removed in more than 30 years.
Before reaching for that Phillips screwdriver to do a repair or maintenance PLEASE do yourself a big favor and visit the following link. It explains the fact that Phillips screwdriver tips will wreck the crosshead screws (they are not Phillips - they are JIS screws) on your KZ650 and tells how to easily deal with this issue so it will not be a problem.
kzrider.com/forum/21-tools/532335-budget...ewdriver-tips#532335
Before reaching for that wrench or ratchet consider the following. The bolts are steel, but your engine and front forks are aluminum. The bolts are much tougher than the aluminum and if over tightened will strip the aluminum threads. Although these can be repaired, preventing damage by applying proper torque will save you grief, time, and money. Tightening fasteners properly requires torque wrenches. Various vendors, including Snap-on, CDI, Sears, etc., market torque wrenches. The two most popular types are the bar type and micrometer type. Either will work, but the micrometer type is a bit easier to use, especially if you are tightening several fasteners with the same torque - such as cylinder head covers. You will need a torque wrench calibrated in INCH POUNDS for many of the bolts. You will also need a torque wrench calibrated in FOOT POUNDS for the larger bolts. Don't try to use the foot pounds wrench on the smaller bolts as it will not be sensitive enough at low torque settings to provide accurate torque. There are many fasteners that require low torque. These include such things as 6mm oil pan bolts, cylinder head cover bolts, etc. for which the torque in 61-78 inch pounds. These low torque bolts require a wrench that is accurate at low settings and this wrench should be graduated in inch pounds. In addition, there are numerous high torque fasteners such as the front axle nuts (51 - 65 foot pounds) or swing arm pivot shaft nuts (58 - 87 foot pounds). These require a wrench that is accurate at higher settings; this wrench should be graduated in foot pounds. Using the proper torque wrenches to correctly tighten fasteners will help prevent damage and contribute to a safe bike. The Kawasaki Service Manual will list the various torque specs for the bolts. I suggest you get the manual before buying the torque wrenches so you can decide which wrenches best meet the torque specs.
MOTOR OIL
The ingredients in oils have changed over the years. For example, today's Castrol GTX oil (and pretty much all other AUTOMOBILE oil) is not the same as it was in the 1980's. Back then it worked great in KZ bikes. But, things have changed. Early AUTOMOBILE oils contained zinc phosphorus compounds (ZDDP) to protect engine components from metal to metal contact. This was good for engines, but it was found to be destructive to catalytic converters. Consequently, in AUTOMOBILE oils ZDDP was virtually eliminated and replaced with different chemistry generically referred to as "Friction Modifiers." These work fine and offer good protection for normal AUTOMOBILE engines. However, today's AUTOMOBILE oil "Friction Modifiers" are destructive to wet clutches. KZ bikes (and many other brands) have wet clutches. As a result of these oil chemistry changes a distinction needed to be made between those oils which are suitable for wet clutches and those which are not. That distinction was documented by the Japanese Engine Oil Standards Implementation Panel (JASO). JASO developed a number of different oil specifications for different applications. The specifications that apply to 4 stroke motorcycles fall under the "4T Specifications." Within the 4T specifications the JASO MA class oils are specifically formulated for 4 stroke motorcycles with wet clutches.
There are synthetic, semi-synthetic, and non-synthetic oils that meet the JASO-MA standard and any of them will work ok. However, using oils that are not designated as meeting the JASO-MA standard is destructive to KZ clutches.
TOOLS
Attachment 00000_2013-06-13-2.jpg not found
MOTOR OIL
Replied by 531blackbanshee on topic even more swingarm questions, yaaaaaay!
12 Jun 2013 17:27
a thread on custom fighters has alot of swingarm pivot width info.
www.customfighters.com/forums/showthread.php?t=55407
it list the 05 gsxr 1000 @ 225mm
and the 01-02- gsxr 1000 @228mm
couldn't find the 03 gsxr 1000 width. :pinch:
Replied by Plug.ugly on topic even more swingarm questions, yaaaaaay!
12 Jun 2013 15:59
I'm sorry, to be more clear, the pivot point on the stock arm is 8.5. Not sure what it is on the gsxr swingarm. I've heard it may require some shaving. I can't for.the life of me find the measurement online before I buy the part. My google fu is off these days.
Replied by MFolks on topic Tank Slap ??
12 Jun 2013 14:13
I copied this from a post from Jeff Saunders(owner of Z1 enterprises)
Motorcycle Wobble Causes
There's a LONG list of potential area that can cause this.
These are not in any particular order
Wheel bearings
Steering bearings - repack grease, check tightness
Swing arm bushings/sleeves/bearings - replace is worn, repack grease
Fork springs aging - check spring length
Unequal fork oil - if seals leak, then your damping can be ineffective
Rear shocks aging, damper leaks - if you have oil leaking from the seals, the damping is toast.
Worn Tires/Mismatched tires/tire pressures/wrong size tires
Wheel alignment - don't trust the chain adjusters - I visually align the wheels.
Bent rims/broken spokes - get the wheels off the ground and spin them - check for runout / damage
Front disc warped - check for runout
Steering & swing arm bearings are very common problems, but so are tire issues (pressure/mismatch) and wheel alignment.
From www.kzrider.com 650ED
Here’s how I was taught to balance a tire/wheel. Put the axle through the wheel bearings and suspend each end of the axle on something high enough to keep the tire from touching the floor (I use ice chests because I don’t have bar stools :laugh: ). Give the tire a gentle spin – it should rotate freely for a while before stopping. When it stops put a small piece of masking tape on the wheel at the 12:00 o’clock position. That is the lightest side of the wheel/tire combo. Give it another spin. When the tire stops spinning the masking tape should be at the 12:00 o’clock position again. This verifies that is the lightest spot. Tape 2 separate 1/2 oz. weights where you marked the light side. Spin the tire. When the tire stops spinning if the weights end up at 12:00 o’clock replace the 1/2 oz. weights with 2 slightly heavier weights – maybe 3/4 oz. and try again. If the weights end up at the 6:00 o’clock position trim a little equal amount off each on and spin it again. When you have found the correct amount of weight the tire will stop at different positions each time you spin it.
Now here’s why you use 2 weights. You now need to move one weight 60 degrees to the left of the spot you marked as being light and move the other weight 60 degrees to the right of that spot. Tape them in their new locations and spin the tire. It should stop in a different location each time. If not; adjust both weight a little but by equal amounts until it does. Once you reach the point where the tire stops at a different place after each spin mount the weights in those positions.
By moving each weight 60 degrees away from the light spot you have created 3 points on the wheel that balance it out, the original heavy spot and 2 weighted spots, and these 3 points are evenly distributed around the wheel – each is 120 degrees from the other. If you only use a single weight and place it 180 degrees away from the heavy spot you create a barbell effect that is not desirable. Ed
Wheel bearings
Replied by DrWhizBang on topic Engineering build complete on KZ650
12 Jun 2013 12:21
It is 1000% better than it was last year. It feels familiar since it is still MY bike, but it does not feel like a 35 year-old anymore - it is rock solid! Of course, I can't point at any one thing that makes the difference since I did the swingarm, the wheels/tires and the springs all at once. Once I address the speed wobble, my wife will no longer be leaving me behind with her FZ6
Leon, you'll be interested to know that I found a local semi-retired machinist, so I got a very reasonable price on the spacers I needed for the rear axle. I'll have to get as many parts made as possible before this guy sells his equipment!
Displaying 2261 - 2270 out of 7259 results.
