even more swingarm questions, yaaaaaay!
  • Plug.ugly
  • Plug.ugly's Avatar Topic Author
11 Jun 2013 20:30
#591813
Ok so do to having more money than spare time, I'm looking into other options in regards to building my bike. I've got a79 kz400. I was originally goin to stretch the stock swingarm myself but as I've said, time has been short for me.
Now as I understand it thanks to lurking around, a gsxr swingarm is a likely candidate for a swap.
First, is this true?
Secondly if it is, will it really matter if its from a 600/750 or a 1000?
Thirdly, what kinda issues can I expect to run into and what else will be necessary to make this swap? I know the obvious things like wheel, shock and links. But what else?
Thanks in advance guys.
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: even more swingarm questions, yaaaaaay!
12 Jun 2013 00:44
#591868
The gixxer arms are good candidates for swaps.the early 90's ones are popular.
Pivot bolt diameter
Pivot width
Chain alignment
Those are some concerns right off the bat.
Leon
The following user(s) said Thank You: Plug.ugly
  • Plug.ugly
12 Jun 2013 10:58
#591918
I am looking at a 2003 1000 arm. I plan on running the mono setup. It is stretched as well.
  • 531blackbanshee
  • Vendor
  • Vendor
12 Jun 2013 12:16
#591928
what is your inside diameter of the frame at the pivot bolt area?
  • Plug.ugly
12 Jun 2013 15:33
#591954
I'll have to measure it again, buy off the top of my head I know the pivot point on the arm is 8.5
  • 531blackbanshee
  • Vendor
  • Vendor
12 Jun 2013 15:35
#591956
that measurement is going to determine how easy the swaps going to be.
  • Plug.ugly
12 Jun 2013 15:59
#591960
I'm sorry, to be more clear, the pivot point on the stock arm is 8.5. Not sure what it is on the gsxr swingarm. I've heard it may require some shaving. I can't for.the life of me find the measurement online before I buy the part. My google fu is off these days.
  • 531blackbanshee
  • Vendor
  • Vendor
12 Jun 2013 17:27
#591979
a thread on custom fighters has alot of swingarm pivot width info.
www.customfighters.com/forums/showthread.php?t=55407
it list the 05 gsxr 1000 @ 225mm
and the 01-02- gsxr 1000 @228mm
couldn't find the 03 gsxr 1000 width. :pinch:
  • Plug.ugly
12 Jun 2013 21:51
#592027
I would imagine the 03-04 arm will fall somewhere between those numbers, which means a pretty minimal amount of shaving. Anywhere between .35 to .5 of an inch.
