Home Upgrade Project...
- Wheelhop
Re: Home Upgrade Project...
31 Jan 2023 12:10As a Construction Safety Technician by profession- I would like to see you move the gas bottle away from the ignition source (cap it when not in use) and secure it from falling over in it's new location.
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
- Nerdy
31 Jan 2023 13:50 - 31 Jan 2023 14:02Yeah, I used underground rated PVC pipe to house 6g copper wire. The house breaker is 50A, but I used 40A in the new sub-panel. The in-garage wire, from the panel to the outlet, is 8g. While I was at it, I also ran a new 120V line to the side of the garage without power. The garage needs more lighting, so that may be the next project.
If I were re-doing the workshop, I would go with the native-LED (not converted) 4' lights: low power consumption and great looking output. I used the 4' fluorescent fixtures and while there are tube-shaped LED replacements, I don't want to switch over while I still have a box of fluorescent tubes. (The ballasts are still good.)
When my parents got a new shed several years ago, my brother ran the wiring and installed a metric boatload of those 4' LED fixtures. The shed could double as an operating room.
EDIT: if you're keeping some of the wiring and you have those ceramic lamp holders that take a single screw-in light bulb, you can get LED replacements for those. The replacements screw in as well, so they're really easy to use. Home Depot has some that have adjustable light color/temperature and look nice (plain white with frosted shades) and on Amazon I got some that are labeled "deformable lights", meaning they have three flat LED light pods that can be angled as you like. They're also super frickin' bright.
EDIT2: these are the Home Depot lights - www.homedepot.com/p/Commercial-Electric-...g-54690111/300188965
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Last edit: 31 Jan 2023 14:02 by Nerdy.
31 Jan 2023 17:30 - 01 Feb 2023 06:37Any particular brand...that doesn't break the bank? I bought a Phase 2 quick change tool post, which is considered one of the better asian versions. A real deal Aloris is nose bleed expensive, and I didn't need to go there.Add a key-less chuck (for the tail-stock) to your list of "must have" tooling...
H.
Edit: doing some digging and the Rohm brand of keyless chucks seems hits the value target. I'm searching best deal now...
Last edit: 01 Feb 2023 06:37 by Nessism.
01 Feb 2023 06:25
Blipco
I deleted your last post
It was corrupted Seems like your attachment was all code and no pictures
Try again but be careful with the pictures
- blipco
- 2002 KZ1000P
01 Feb 2023 06:35Blipco
——>>> Yeah, something went wrong with my iPad so I tried to fix it myself.
Not good result.
- blipco
- 2002 KZ1000P
01 Feb 2023 06:43
Here’s my lighting for my 12x16 foot shed with a fairly high roof.
I have ten 90 watt led, one high output highway tunnel led fixture which will burn your retinas if you look directly at it and two homemade brake rotor fixtures on a separate switch for ambiance. I’m an electrician and I like light.
There are six receptacles including one on a separate switch for the stereo.
Not shown is the fact that the whole shed is plugged into an outside receptacle under my back porch, LOL.
01 Feb 2023 06:55
Nice shop
Picture problem solved too
- Wheelhop
01 Feb 2023 07:14The "Shed-Mahal" !! Nice, I love it.Here’s my lighting for my 12x16 foot shed with a fairly high roof.
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
01 Feb 2023 07:21Anyone else see the interesting overhead lighting decor? Wheelhop is going to request some safety cables on them. If they fall that could hurt.
- blipco
- 2002 KZ1000P
01 Feb 2023 09:36Good eye but… Each of those fixtures is supported by THREE #12 jack chains. I wasn’t worried about me, more like one of my babies receiving a dent in the tank. Plus the three chains look most elegant.Anyone else see the interesting overhead lighting decor? Wheelhop is going to request some safety cables on them. If they fall that could hurt.
I just noticed my Goodyear blimp needs inflating.
01 Feb 2023 10:26Happens when you get old….I just noticed my Goodyear blimp needs inflating.
- Busy
01 Feb 2023 10:30
