  • Page:
  • 1
  • 2
z1r engine noise 07 Jul 2017 19:54 #766362
  • z101mike
  • z101mike's Avatar Topic Author
  • Thank you received: 1
can the cam chain tenisoner be removed with no problems (stuff fall in side engine?)wow my verification just expired while tiping
z1r engine noise 07 Jul 2017 19:56 #766364
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
Why would you want to remove it?
z1r engine noise 07 Jul 2017 20:15 #766367
  • z101mike
I know the carbs need sycronized
z1r engine noise 07 Jul 2017 20:18 #766368
  • SWest
  • SWest's Avatar
  • 10 22 2014
If you remove it don't turn the engine. What does that have to do with the carbs?
z1r engine noise 07 Jul 2017 20:32 #766370
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 633
z101mike wrote: I know the carbs need sycronized
Sleep on it and take a fresh look in the morning...you might be surprised to figure out the problem in the midst of a dream. :)
1982 KZ1100-A2
z1r engine noise 07 Jul 2017 20:37 #766372
  • SWest
  • SWest's Avatar
  • 10 22 2014
Got a manual?
z1r engine noise 07 Jul 2017 20:39 #766373
  • z101mike
It has 8455 miles so I would think it wouldnt be piston slap
z1r engine noise 07 Jul 2017 20:44 #766375
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
  • Thank you received: 87
If you have a full service manual check the procedure to tighten exhaust manifold when its cold in the morning,Not when its hot
The following user(s) said Thank You: z101mike
z1r engine noise 07 Jul 2017 21:01 #766377
  • z101mike
this thing runs like a scolded ape,back tire breaks lose at 50mph with a twist of the grip, in 3 gear felt like i was on ice.the kawasaki dealer that owned this bike did a lot to the engine before my brother got it.he painted pro/street on the back fender and I believe it
z1r engine noise 08 Jul 2017 00:28 #766386
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
  • Thank you received: 107
Would be interesting to know what modifications have been done - spinning the tire in third with throttle only is way above stock Z1R performance, even for the Z1R-TC. What RPM does it run at 60 mph?
How about posting a half dozen or so of pics for us? If it isn't turbo, then it is likely min. 1260 cc for that level of power.
-Scott
z1r engine noise 08 Jul 2017 06:07 #766392
  • z101mike
My brother bought this bike from a dealer in los vegas in 82 and was told that the motor had hotter cams weisco big bore kit 1200 i think and the head had been ported.It is not the turbo bike.
z1r engine noise 08 Jul 2017 06:17 #766394
  • SWest
  • SWest's Avatar
  • 10 22 2014
I asked some pertinent questions but no answers. :unsure:
  • Page:
  • 1
  • 2
