  • Page:
  • 1
  • 2
kz400 tire sizes 16 Feb 2015 22:55 #661835
  • DoctoRot
  • DoctoRot's Avatar Topic Author
  • Thank you received: 664
The stock kz400 calls for a 3.25/18 front yokohama and a 3.50/18 rear yokohama. On every conversion chart i have seen a 3.25-3.50 /18 is equivalent to a 100/90/18 tire. The kz400 comes with 1.85 rims front and back. The 90/90/18 from Avon has a minimum recommended rim size of 1.85. The smallest rim size for100/90/18 tire is 2.15. I was planning on running the avon 90/90/18 front and 100/90/18 rear but this would be too small rim suggested by avon for the rim. It seems the kawi was going to big from the factory. should i go 90/90/18 on the rear too?
side note. is it possible the rim measuring system then has changed just like the tire measuring? So the 1.85 is more like a 2.50
Last edit: by DoctoRot.
kz400 tire sizes 16 Feb 2015 23:07 #661836
  • DoctoRot
btw the bike currently has a 3.50/18 front and a 3.75/18 rear from the PO
kz400 tire sizes 17 Feb 2015 05:34 #661846
  • Nessism
  • Nessism's Avatar
  • Away
  • Thank you received: 2684
You can go 100 on the back no problem. I've seen guys go 110 on a 1.85 rear before, although it's not ideal.
kz400 tire sizes 17 Feb 2015 06:08 #661849
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2635
It's hard enough to get my paws in the tire/rim to put in the valve stem. Any smaller, I couldn't do it. Try Chaparral to see what they have to offer. I have a 110/90 on the front and there is no room left. The 100/90 would wash out too easy on dirt and squirrely on the turns. I have a 130/90 V rear. I'd like bigger but not in the program.
kz400 tire sizes 17 Feb 2015 07:35 #661852
  • DoctoRot
thanks for moving this admins.
kz400 tire sizes 18 Feb 2015 11:13 #661980
  • 77Davo650
  • 77Davo650's Avatar
  • Thank you received: 4
I have 3 78 kz400's with the spoke wheels, I am running 110/90/18 on the rear and 100/90/18 on the front on two of my bikes. On the third one that I chopped, I'm running a 110/90/18 on the front and it barely clears the fender mounting bolts and I don't ride that one nearly as hard either, but it does fit. All my bikes have 1.85 fronts and 2.15 rears, however I have a kz400 part-out that I saw has a 2.15 front, not sure if that was someone relacing that wider rim to the front hub or if it was somehow like that from factory (maybe the deluxe model?). I also had a kz440 partout that I think had 1.85 front and rear and came with 3.00-18 tires on it which looked riduculously skinny.
77 KZ650 C1 (sold)
78 KZ650 B2 (sold)
78 KZ400 B1 (sold)
78 kz400 C1 (resto-mod)
78 kz400 C1 (hardtail low chop)
couple of possible project kz's in parts
Last edit: by 77Davo650.
kz400 tire sizes 19 Feb 2015 17:35 #662099
  • Nebr_Rex
  • Nebr_Rex's Avatar
  • Thank you received: 298
90/90/18 & 110/90/18 on my KZ400 that has the stock rim sizes.
The other bike with a 2.15 rear is 100/90/18 & 120/90/18.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
kz400 tire sizes 20 Feb 2015 12:33 #662153
  • DoctoRot
The deluxe is like the other 400's with a 1.85 rim front and back. I went with a 90/90/18 front and a 100/90/18 rear Avon roadriders. thanks for replies guys.
kz400 tire sizes 24 Oct 2020 09:26 #837613
  • quantum sloth
  • quantum sloth's Avatar
  • Thank you received: 0
I have a 79 kz400 ltd and I. The fro t it has 100/90/19 and on the rear it has 130/90/16 is this correct.
kz400 tire sizes 06 Feb 2024 21:54 #894930
  • LuisLAN
  • LuisLAN's Avatar
Which year KZ400 had 2.15 spoked rear wheels? I've been reading here trying to find the answer, but all I came up with is that some have 2.15 wheels and some 1.85.
I would like to swap the 1.85 I currently have for something wider, so far the easiest way seems to be a 2.15 from another kz400.
Maybe lace a 2.5 wheel on to the hub?
What is your experience with this mod?
kz400 tire sizes 07 Feb 2024 04:47 #894933
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
Possibly the Ltd models.  the 79 400H Ltd had cast alloy wheels.
Kawasaki.com and Partzilla have parts diagrams but partzilla is easier to use, since you can zip around from model to model a lot faster.
Last edit: by martin_csr.
kz400 tire sizes 07 Feb 2024 08:32 #894941
  • LuisLAN
  • LuisLAN's Avatar
Thank you Martin_csr for taking the time to reply.
I tried Partzilla, they list the part numbers but do not have the wheel size listed with it.
I see 3 different part numbers but no way to tell which one is 2.15.
  • Page:
  • 1
  • 2
