KZ400 Position Lights 02 Jan 2023 04:49 #878431
  • Feanor_twh
  • Feanor_twh's Avatar Topic Author
  • Thank you received: 9
Finally and after many unsuccessful searches I found the solution:
- Original rim-lamp for European KZ400, part number 23006-048
- Original optics for European KZ400, part number 23007-064
The really hard part was finding these serial numbers as they don't appear in either Partzilla or any of the diagram pages I found. I had to get an european KZ400 owner to disassembly his headlight.
It remains for me to check if halogen bulbs can be attached to that optic, I still don't know the type of socket it comes with.
Thanks.
(1976) Kawasaki KZ400-D3. All original, but: electronic reg/rec (Oregon Motorcycle Parts), new handlebar controls (w/ PASS/HORN/lights switch, LED dash lights (superbrightleds.com), Dynatek coil (3ohm), MAC mufflers, HEL brake hoses, rubber fork boots, 4.00 rear tyre (Dunlop K70), chromed chainguard
The following user(s) said Thank You: Nerdy, Wookie58
Last edit: by Feanor_twh.
KZ400 Position Lights 02 Jan 2023 11:02 #878456
  • Nerdy
  • Nerdy's Avatar
  • Away
  • Thank you received: 379
Thank you for posting the answer to your problem! :-)
So many people don't do that, and we don't know if the suggestions we make are any good.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
KZ400 Position Lights 21 Jan 2023 17:24 #879132
  • Feanor_twh
Not so simple. I found out that to ensure future spare parts it is necessary to upgrade to H4. For this I got a complete EMGO headlight for classic Honda's that matches in measures with the KZ400 (6 1/4") but not quite on the bolt mounts
The headlight I got is 100% metal and while I still have my doubts if I'll be able to fit it into the original bowl, I'm more preocupated about the new H4 halogen bulb will melt the original plastic bowl...
KZ400 Position Lights 23 Jan 2023 03:59 #879194
  • Feanor_twh
Does anyone know if these old plastic bowls resist the higher heat generated by an H4 halogen bulb?
KZ400 Position Lights 23 Jan 2023 04:37 #879196
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1789
To the best of my knowledge the heat (along with the light) is reflected outwards through the lens by the reflector so I can't imagine you will have a problem
The following user(s) said Thank You: Feanor_twh
