CAP NEEDLE
- danr123
Re: CAP NEEDLE
28 Nov 2023 14:37
LOOKS LIKE A FLOAT BOWL VENT
Re: CAP NEEDLE
28 Nov 2023 14:48
It's part of the carb body, and not sold separately. You should be able to cobble something together from items at the hardware store, though. As Steve mentioned, it's a vent line. Not a critical component. In fact, you could likely chip off the rest of the broken plastic elbow, and slip a rubber hose over the brass piece. Run the hose down to the ground, away from the rear tire. If you get a leak, you don't want gas dumping on the rear tire.
The following user(s) said Thank You: SWest, howardhb
- danr123
Re: CAP NEEDLE
01 Dec 2023 05:38
Sumting strange going on here. The original post with the question is showing up after the answers. Do we have a hot tube time warp going on.
Re: CAP NEEDLE
01 Dec 2023 06:03And the picture we were asked to remove has re-appeared ???????????????? anyway did somebody say "hot tub"Sumting strange going on here. The original post with the question is showing up after the answers. Do we have a hot tube time warp going on.
Re: CAP NEEDLE
01 Dec 2023 09:34
Re: CAP NEEDLE
01 Dec 2023 11:46
The original post didn't have the engine number "obscured"
Re: CAP NEEDLE
01 Dec 2023 12:45
I received a email and was asked to remove the picture with the engine number
Which I did , b ut left the post containing the parts diagram and the text too
Just a mix up
Ghosts
Just a mix up
Ghosts
Re: CAP NEEDLE
01 Dec 2023 15:20
Tanks! Dirk!
- Moose1800
Re: CAP NEEDLE
02 Dec 2023 07:06It would be a shame if that engine number got out to the public, imagine what could happen........The original post didn't have the engine number "obscured"
The following user(s) said Thank You: Nessism, Mikaw
Re: CAP NEEDLE
02 Dec 2023 07:31Just doing what a member requestedIt would be a shame if that engine number got out to the public, imagine what could happen........The original post didn't have the engine number "obscured"
I hear you , but no big deal
The following user(s) said Thank You: Moose1800
