Mikuni Flatslides Bell crank wheel
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Mikuni Flatslides Bell crank wheel
28 Mar 2023 13:14
#882127
joe
 if you want to ship to Maryland I have had many sets of Mikuni Flatslides apart shoot me a PM if you do not want to tackle yourself
Barry
PM doesn't work but I can put you in touch by email if you are both in agreement
I am ok with it
1984 750 Turbo
The following user(s) said Thank You: rivman15, Wookie58
  • rivman15
  • rivman15's Avatar Topic Author
11 Apr 2023 04:26
#882898
Email works for me. Thanks.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
11 Apr 2023 04:32
#882899
Hi Joe - I sent it to your frontiernet email 31/3/2023, I guess that is old news. Have forwarded to your gmail
  • DFIGPZ
  • DFIGPZ's Avatar
11 Apr 2023 14:56
#882937
if you decide to email me put "MIKUNI Flatslide repair " in subject line
Barry
1984 750 Turbo
  • rivman15
12 Apr 2023 16:09
#882989
I did not realize my very old email was still in there, Holy cow I have been on here along time. New email has been updated. Thank you.
  • rivman15
23 Apr 2023 08:01 - 23 Apr 2023 10:06
#883599
I am going to take a stab at this. Can you remove just half the carbs off the bar to get to the bell crank or does it have to be completely dis assembled?
Last edit: 23 Apr 2023 10:06 by rivman15.
  • rivman15
23 Apr 2023 10:08
#883616
Do you have to remove everything off the throttle shaft to split the carbs?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
23 Apr 2023 10:15
#883619
In my opinion you only have only remove carb# 1+2 to slide out the cank wheel to the LH site of the throttle shaft.
  • rivman15
23 Apr 2023 10:20
#883621
Taking a quick break. There must be another doll pin I havent seen. I was trying to remove carb #4 first and it appears to be still locked on(loose but not coming off)  Throttle bar is still attached I can see it would be easy to replace as soon as I can get that throttle shaft off.
  • rivman15
23 Apr 2023 10:35
#883625
There has be to something else holding the throttle shaft on. Not sliding out.
  • Mikaw
  • Mikaw's Avatar
23 Apr 2023 10:42
#883626
Do as Scirocco says. Remove 1&2. Taking off 3&4 gets you into the return spring and cable bracket.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
23 Apr 2023 11:15 - 23 Apr 2023 11:18
#883627
I do never understand the people asking here for help and than do the opposit as suggested
What a waste of life time sometimes.....
Last edit: 23 Apr 2023 11:18 by Scirocco.
