  • Page:
  • 1
  • 2
Throttle Return Spring 20 Jun 2021 07:32 #850455
  • Jakob
  • Jakob's Avatar Topic Author
  • Thank you received: 0
Hello,
Just got my a 1983 kz750 Ltd4 a couple months ago, wouldn't start so I cleaned the carbs and she's up and running! Realized after taking it around the block that the throttle hangs open if I don't push it back and there's not enough force on the throttle cable to return back to idle.
Here's a couple questions:
1. Is it supposed to have a return cable?
        It only came to me with one cable for the throttle. I didn't notice a spot for a return cable connected to the carbs or anywhere to screw one in.
2. Is it possible the return spring is just weak?
        I put some oil down the throttle tube hoping it would help but it didn't seem to really aid my situation. The return spring works, but I have to push the cable back so far before it starts to actually pull it back. I adjusted at both ends but there seems to be some play that I can't get rid of.
I am hoping I don't have to remove the carbs to get to the spring, but I looked and it looks like I might. Any tips?
Thanks,
Jakob
Throttle Return Spring 20 Jun 2021 12:46 #850479
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2081
If yours is a 1983 H4, then I believe it is supposed to have two cables. However, it should work ok with just one. I think the 750 F1 used a single cable, as did the 1980 H1.
Perhaps your cable is gummed up or fraying. If you are following the proper factory procedure for adjusting the cable, you should easily be able to adjust all of the slack out unless the cable is really stretched.
The following user(s) said Thank You: Jakob
Last edit: by TexasKZ.
Throttle Return Spring 20 Jun 2021 14:25 #850484
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
I'm not familiar with the H4 but i believe it uses the same carbs as the E1. The spring was super weak on the rack i rebuilt I added a stiffer spring and it solved the issue.
Last edit: by DoctoRot.
Throttle Return Spring 20 Jun 2021 20:09 #850507
  • Jakob
Thank you so much for the replies. I will check the cable adjustment procedure to make sure I'm doing it correctly and will look into springs. @DoctoRot - which spring did you end up going with? I'm checking online right now for spring and found one on ebay for 40 bucks. I'm hoping I can find something cheaper.
Thanks,
Jakob
Last edit: by Jakob. Reason: Accidentally sent two posts instead of one.
Throttle Return Spring 21 Jun 2021 09:28 #850528
  • DoctoRot
  • DoctoRot's Avatar
I added an extra pin and a spring from the hardware store. It wasn't the most elegant solution but it worked.
Throttle Return Spring 21 Jun 2021 09:33 #850529
  • Jakob
Have you guys seen a throttle cable like this? I'm trying to buy a new one and cannot for the life of me find one with that sort of circular lip that comes out just before the curve.
Throttle Return Spring 21 Jun 2021 12:20 #850542
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2635
Looks like Honda
Throttle Return Spring 22 Jun 2021 04:38 #850580
  • Jakob
Thanks! I'll keep looking around based off of that.
Throttle Return Spring 22 Jun 2021 06:42 #850581
  • SWest
  • SWest's Avatar
  • 10 22 2014
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationLooks like I was wrong.
Throttle Return Spring 22 Jun 2021 08:59 #850586
  • Jakob
Holy crap that's it! I've been looking like crazy couldn't find it at all. Thanks so very much!
Throttle Return Spring 22 Jun 2021 09:07 #850587
  • Jakob
All right, sorry for being so needy I'm still a newbie, is that cable the push/pull and mine the opposite?
Trying to find one with threads on the other end.
Here's a pic attached.
Throttle Return Spring 22 Jun 2021 13:26 #850597
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1911
Your bike/carb/RH throttle is a pull only cable driven. Try to read the part# that is print on. It make the search much easier for all of us.
Alternative you can buy a slotted adjustment screw.
Last edit: by Scirocco.
  • Page:
  • 1
  • 2
