Main Jet Size Relationship To Jet Needle Position
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
26 Mar 2020 08:05
#821807
Trying to grasp the needle-clip position relationship between two Main Jet sizes.
Do I have a 115 when the clip is in the top slot, and a 117.5 with the clip in the bottom slot, and essentially a 116.25 if the clip is in the middle?
:blink:
1982 KZ1100-A2 bike
1984 ZN/ZX1100 motor
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Main Jet Size Relationship To Jet Needle Position
26 Mar 2020 08:26
#821808
It's mainly for altitude changes. I doubt it would cover that large a jump just like the pilot air screw. I think you'd have better luck with the main air/bleed jets.
  • zed1015
  • zed1015's Avatar
26 Mar 2020 10:15
#821817
The size of the main is the size of the main, nothing will change that.
The needle is a metering device and the taper controls the rate of fuel feed at a particular throttle opening.
Lifting or lowering the needle only allows small changes to increase or decrease that feed to fine tune the mix.
The following user(s) said Thank You: daveo, Gdizard
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
26 Mar 2020 10:40
#821818
Not sure if this will help or not but here is a page from a mikuni carb manual that shows the change in fuel flow between the slots.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • daveo
  • Premium Member
  • Premium Member
26 Mar 2020 11:00
#821822
Very helpful information guy's. I think my jetting is close, if not dead on for the present cool weather conditions.
Amazing how one minuscule jetting change can detrimentally alter things.
:huh:
1982 KZ1100-A2 bike
