  • Page:
  • 1
  • 2
Missing center stand 07 Mar 2016 08:26 #714269
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar Topic Author
  • Eschew Obfuscation!
  • Thank you received: 62
Apologies if this has been addressed previously....My son just bought a 1980 ltd 1000 with a star racing "sideshot" exhaust..(which I am assuming is the reason the center stand was removed!) How does one perform basic maintenance/repair tasks without one? Even simple chain adjustment procedure calls for one? I have a HF hydraulic bike jack that won't work on KZ's due to engine/exhaust sticking out below frame rails...He wants to bolt together some sort of "gantry" from which to "hang" bike, or possibly remove back half of 4 to 1, & temporarily re-install center stand for maintenance...Any suggestions? Thanx, all!
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
Missing center stand 07 Mar 2016 08:33 #714272
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
I removed mine years ago and just slip it on and off in the garage when I need it....... I've done it so many times I can get the pin in and out in 10 seconds or less ......spring is not needed.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Missing center stand 07 Mar 2016 10:00 #714287
  • GPzMOD750
  • GPzMOD750's Avatar
  • Thank you received: 148
I had to take my center stand of when I put my 4-1 on. I use a paddock stand from harbor freight. Cycle Gear has good pieces on them too.
Sometimes you just have to take the exhaust off to get at certain unrelated things. Also, many of the higher speed exhaust set ups have quick remove features. Usually a spring and loop.
Missing center stand 07 Mar 2016 11:58 #714303
  • redhawk4
  • redhawk4's Avatar
  • Thank you received: 64
The KZ1000Ltd's never came with a center stand because one would not fit with the stock Mac exhausts. They have the frame lugs so one can be fitted exhaust system permitting. If you just use it as a shop stand, without the spring etc. then there wouldn't be problems with most exhausts, it's a different matter if you want to retract it and ride with it in place.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
Last edit: by redhawk4.
Missing center stand 07 Mar 2016 14:10 #714323
  • floivanus
  • floivanus's Avatar
  • Thank you received: 116
Thought ltds had jardine exhausts?
Past; 78 kz1000, 83 kz550
Andrew
Missing center stand 08 Mar 2016 09:54 #714482
  • pete greek1
  • pete greek1's Avatar
  • Thank you received: 185
floivanus wrote: Thought ltds had jardine exhausts?
They did, these are the ones from my 80 LTD
Pete
Missing center stand 08 Mar 2016 17:49 #714542
  • rstnick
  • rstnick's Avatar
  • Thank you received: 374
A rear stand lifting on the swingarm can work.
I had to remove my center stand, and cut off the mounts to fit a braced swingarm.
The swingarm has spools now, so the stand lifts on them.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Missing center stand 09 Mar 2016 12:06 #714637
  • redhawk4
  • redhawk4's Avatar
I knew what I meant :) either way they didn't work with a center stand and that's why they weren't fitted.
1977 KZ650B1
1980 Suzuki SP400
Missing center stand 09 Mar 2016 12:27 #714639
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
I had Jardine pipes with cross overs and a centerstand.
Missing center stand 09 Mar 2016 13:03 #714650
  • redhawk4
  • redhawk4's Avatar
I have read it several times that's why Ltd's didn't have center stands, but that doesn't mean it's right, but they didn't come with center stands.
1977 KZ650B1
1980 Suzuki SP400
Missing center stand 09 Mar 2016 13:36 #714655
  • SWest
  • SWest's Avatar
  • 10 22 2014
Maybe because of the 16" rear wheel.
Missing center stand 09 Mar 2016 15:00 #714659
  • redhawk4
  • redhawk4's Avatar
It had occurred to me the stand would perhaps need to be shorter, or it would be a bugger to get it up on the stand with it sitting 3/4" or so lower.
1977 KZ650B1
1980 Suzuki SP400
  • Page:
  • 1
  • 2
