Carb Stand from old carb holders. 27 Aug 2012 18:47 #545141
  • porchev914
  • porchev914's Avatar
  • Thank you received: 19
Thats pretty cool Mark, now I see what you wanted some help with :evil: One suggestion i might make is to make the plate the carbs bolt to slide into the side stands. That way you can flip the carbs upside down to work on the bowl side B)
FRANKEN Z!
Carb Stand from old carb holders. 29 Aug 2012 13:36 #545473
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
  • Thank you received: 36
porchev914 wrote: Thats pretty cool Mark, now I see what you wanted some help with :evil: One suggestion i might make is to make the plate the carbs bolt to slide into the side stands. That way you can flip the carbs upside down to work on the bowl side B)
Yes, exactly! Though, I went for sturdiness instead of flipping - I was trying to scheme up a way to do that, but I couldn't without either 4 bolts (which take as much time to undo as 4 carb holders) or a seriously floppy workstand. I don't like floppy workstands. :silly:
2000 ZRX 1100
1976 KZ 900- Daily Driver
Carb Stand from old carb holders. 30 Aug 2012 22:33 #545772
  • porchev914
Post up the dimensions for that stand. I have an idea Mark......
FRANKEN Z!
Carb Stand from old carb holders. 23 Aug 2014 21:11 #644955
  • Whome
  • Whome's Avatar
  • Thank you received: 0
I got a lot of really good ideas on here but that's freekin' killer.
Dan
Carb Stand from old carb holders. 04 Sep 2014 06:59 #646217
  • Grumpy Ole Artist
  • Grumpy Ole Artist's Avatar
  • Eschew Obfuscation!
  • Thank you received: 62
Low budget (2 scraps of wood, and a few drywall screws) nowhere NEAR as elegant & sexy as some of the others here, but necessity is a mother!
1978 KZ650 B2
Former rides...1976 CB360T, 1985 Shadow 700, 1985 GPZ750Turbo
Carb Stand from old carb holders. 04 Sep 2014 08:09 #646222
  • loudhvx
  • loudhvx's Avatar Topic Author
  • Thank you received: 1615
Can't argue with what works! B) It's like folk art, it may not be pretty, but I like it! :)
Last edit: by loudhvx.
Carb Stand from old carb holders. 14 Nov 2015 16:45 #698675
  • Mean Green Z28
  • Mean Green Z28's Avatar
  • Kawasaki NooB
  • Thank you received: 5
dammit just saw this. I threw away the old parts when I replaced them and had to do this ...
then realized I can't get to the drain screws! haha
2010 Camaro 2SS
1983 Kawi KZ1000P ... bag of bolts
Carb Stand from old carb holders. 15 Nov 2015 04:03 #698717
  • NakedFun
  • NakedFun's Avatar
  • Thank you received: 99
So I have been thinking about this for a while, but was thinking about utilizing some PVC and a vacuum to help dynamically set the sync prior to final sync on the bike.
Nice creative genius out there building these stands. Nice work guys!
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
Carb Stand from old carb holders. 15 Nov 2015 04:45 #698722
  • kaw-a-holic
  • kaw-a-holic's Avatar
  • Thank you received: 248
Curious, would a shop vac work to sync them on the bench? It wouldn't be the hard to make a manifold to connect to shop vac. Experimentation will have to wait for summer or some rainy winter days.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
Carb Stand from old carb holders. 15 Nov 2015 05:30 #698737
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
I'm going to mount mine on a board and mount them on the wall. Great idea. B)
Carb Stand from old carb holders. 15 Nov 2015 16:07 #698828
  • NakedFun
  • NakedFun's Avatar
kaw-a-holic wrote: Curious, would a shop vac work to sync them on the bench? It wouldn't be the hard to make a manifold to connect to shop vac. Experimentation will have to wait for summer or some rainy winter days.
You could sync them in a rough way that way. About the same as simply static sync'ing them like the manual calls for with a feeler gauge. They would still need some tweaking once on the engine as the vacuum will be unique to each cylinder thus to each carb.
Cory
1976 Kawasaki KZ900
Carb Stand from old carb holders. 15 Nov 2015 22:33 #698884
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
But it is a good way to set the float bowl fuel levels off the bike.
Just put one screw in each bowl and use the clear tube method for best results
Then you can just pop the bowls off to mess with the float tabs.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: by missionkz.
