Carb Stand from old carb holders. 24 Nov 2016 07:55 #748830
  • loudhvx
  • loudhvx's Avatar Topic Author
  • Thank you received: 1615
Very nice on both of those.
Steve, that must get you some questions. :)
Carb Stand from old carb holders. 24 Nov 2016 07:59 #748831
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2613
loudhvx wrote: Very nice on both of those.
No one has asked yet. Maybe they're afraid of the answer. :woohoo:
Carb Stand from old carb holders. 24 Nov 2016 08:22 #748834
  • loudhvx
:laugh: could be.
Carb Stand from old carb holders. 26 Nov 2016 06:02 #748956
  • rstnick
  • rstnick's Avatar
  • Thank you received: 373
Thanks for all the ideas on making a stand.
I used some wood I had laying around.
I don't have a garage, just some work space In the basement.
I wanted my carb stand portable, so I can take it outside.
Also gave the carbs a bath.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Last edit: by rstnick.
Carb Stand from old carb holders. 26 Nov 2016 06:16 #748960
  • JR
  • JR's Avatar
  • Thank you received: 429
Very cute !
Carb Stand from old carb holders. 29 Nov 2016 07:29 #749143
  • BOOM_FIST
  • BOOM_FIST's Avatar
  • Thank you received: 5
I did the same. Unfortunately, I built it with old Mikuni VM26 holders...and when I tried to slap the Keihin 29's on it....DOH! Dumb new guy.
1977 KZ900A5
Carb Stand from old carb holders. 01 Dec 2016 05:05 #749217
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
Carb stand. by removing the horizontal 2x4, it also functions as an engine block/stand which was its original use when I refurbished the front end.
The stand is two 2x4s screwed together then fastened to a 2x8. the carb holder part is a 2x4 w a couple of L brackets to support the carburetors & 2 lag screws to offset the carbs so they'll be level. plus a bungee cord to make sure they stay in place. the natural tendency of vm24 carbs is to lean against the horizontal board.
Last edit: by martin_csr.
Carb Stand from old carb holders. 01 Dec 2016 06:17 #749227
  • SWest
  • SWest's Avatar
  • 10 22 2014
Good tank jig. After 40 years being a carpenter, I never made a table like that :S . :huh: Brought home mountains of lumber but never thought of it. Nice. B)
Carb Stand from old carb holders. 01 Dec 2016 12:21 #749247
  • bluej58
  • bluej58's Avatar
  • Thank you received: 511
My bench is made entirely from recycled 3/4" hem-fir plywood ( 3 sheets)
A work in progress
78 KZ1000 A2A
The following user(s) said Thank You: undiablo
