  • Page:
  • 1
  • 2
stripped spark plug hole - timesert repair 04 Apr 2024 02:34 #897248
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1816
Thanks DaveO. I have been trying but it comes up an error everyone I try and submit it.
Open a post
Click "attachments"
Select pictures from folder and insert (don't drag and drop)
Click "insert all"
Submit
Last edit: by Wookie58.
stripped spark plug hole - timesert repair 04 Apr 2024 13:38 #897260
  • Slj029
  • Slj029's Avatar
  • Thank you received: 6
I did that but an error comes up
stripped spark plug hole - timesert repair 04 Apr 2024 13:39 #897261
  • Slj029
  • Slj029's Avatar
stripped spark plug hole - timesert repair 04 Apr 2024 15:18 #897263
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
The profile of  the 44111 (16.9mm) Time-Sert I used looks similar, but less spark plug end shows in your picture compared to mine.
Check with the Time-Sert supplier below.  They were very helpful to provide information when I was considering the product, and will likely have just what you need:
www.mechanicstoolsandbits.com/
www.mechanicstoolsandbits.com/product-ca...washer-seat-inserts/
The 44111 inserts extend slightly into the combustion chamber in my bathtub head.  This hasn't caused any problems in my running engine, but seeing that I decided to work them down a bit.
1982 KZ1100-A2
The following user(s) said Thank You: Rolf1976_KZ900
Last edit: by daveo.
stripped spark plug hole - timesert repair 13 Apr 2024 19:43 #897611
  • Slj029
  • Slj029's Avatar
So I’ve been having issues looking for the “Time Sert” that came out of my bike. The inside thread pattern on mine fits my plugs fine but the outside thread pattern is 5/8 x 18. I cannot find anything like this. I asked the mechanics tools and bits. They said to order a M14 x 1.25. I did and the outside threads didn’t match. I’m not sure what to do at this point.
stripped spark plug hole - timesert repair 13 Apr 2024 21:46 #897613
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2629
So you used a aftermarket insert not time sert? If so you may have to use a Big sert. I did and it worked out but it was a PITA.
stripped spark plug hole - timesert repair 14 Apr 2024 02:58 #897617
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1470
The outer thread is likely M18 ... METRIC..
stripped spark plug hole - timesert repair 14 Apr 2024 03:54 #897618
  • Slj029
  • Slj029's Avatar
Correct the other thread is m18. But what is the inner thread? Because everything I read says that it’s the same as the outer which my plug will not fit or do I have to run a different plug? And to the other person I didn’t use an off brand I bought the bike then realized the guy I bought it from did.
stripped spark plug hole - timesert repair 14 Apr 2024 10:24 #897628
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
See below for spark plug thread sizes, M14 and M12 are the most common sizes for automotive use
stripped spark plug hole - timesert repair 14 Apr 2024 14:41 #897633
  • SWest
  • SWest's Avatar
  • 10 22 2014
The ones from the auto parts stores fit poorly if that's what you have. The inner is m14 where the outer is some bastard size that won't fit the Time Sert. Does it tighten down and seal? If it does you can try locking sealer on it before going larger.
www.amazon.com/gp/product/B00IZIBJ04/ref...00_s00?ie=UTF8&psc=1
Last edit: by SWest.
stripped spark plug hole - timesert repair 14 Apr 2024 17:29 #897639
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2076
Umm, I think I am confused.
The inside threads of the insert must be the same as your sparkplugs, and I think you said they are the same.
The outside threads of the insert must be the same as the new threads cut into the head. They both will be a larger diameter and different pitch from the spark plug threads. There is no other choice, they have to be different. That way the insert will fit snugly in the head and the spark plug will fit snugly in the insert.
Last edit: by TexasKZ.
stripped spark plug hole - timesert repair 14 Apr 2024 19:21 #897646
  • SWest
  • SWest's Avatar
  • 10 22 2014
I bought some Time Serts and they won't fit the OEM brand (Auto Zone) insert holes. Too loose. They rely on a serrated top edge that you expand with the tool they provide. One split and I had to take it back out. The one I put in didn't fit snugly. The time Sert has a tool that expands the bottom last two threads. Much better design. They are cold rolled and it works well unless the hole is sloppy. The whole thing turned out to be a nightmare. Wish I had used Helicoils as I wanted to in the beginning.
The following user(s) said Thank You: Slj029
Last edit: by SWest. Reason: sp
  • Page:
  • 1
  • 2
