Hydro clutch or pmc easy clutch kit? 22 Feb 2020 13:23 #819699
  • Thank you received: 2829
My 1977 KZ650-C1 has the 8 ball type. I've never taken it apart and after 62,000+ miles it still works fine. Ed
The following user(s) said Thank You: Rick H.
Hydro clutch or pmc easy clutch kit? 23 Feb 2020 02:23 #819721
  • gordone
  • gordone's Avatar
  • Thank you received: 67
I lubed my clutch wirer yesterday, and identify some corrosion after the adjuster midway (with the cylinder 1 exhaust pipe).
Maybe these is the reason for snapping, water comes in here? What do you do to avoid? Have some three bond gasket inside to block the water?
These adjuster:
Project:
Last edit: by gordone.
Hydro clutch or pmc easy clutch kit? 23 Feb 2020 05:20 #819725
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
Good point about the water that I didn't think about. Many motorcycles have a rubber boot that slides on the outer cable and covers the junction for the upper and lower cable housings. I wonder if there is something out there that will work for this.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Hydro clutch or pmc easy clutch kit? 23 Feb 2020 05:37 #819726
  • gordone
  • gordone's Avatar
Rick H. wrote: Good point about the water that I didn't think about. Many motorcycles have a rubber boot that slides on the outer cable and covers the junction for the upper and lower cable housings. I wonder if there is something out there that will work for this.
Rick H.
Please notify if you find something!
Project:
Hydro clutch or pmc easy clutch kit? 23 Feb 2020 05:40 #819727
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2678
old_kaw wrote:
Nessism wrote: Steve,
Your top photo shows a ramp and ball type and the lower down photos show the helix.
The top pic is a helix too. You can see the tabs from the inner retainer.
Thanks for correcting me. My bad.
I had both types when rebuilding my 750 and chose to go with the ramp and ball version which was smoother. It's a little finicky to set up though in that you have to get the ramp in the right position during assembly or there will be no clutch. Going off memory but the arm on the mechanism needs to be at roughly 90 degrees to the cable coming through the cover.
Hydro clutch or pmc easy clutch kit? 23 Feb 2020 07:52 #819731
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
Do you have a part number for the stock ramp and ball unit? As to not hijack this thread I started my own. I'd like to post one of them to provide more choices.
650 Ed, I switched the clamps. Thank's for the heads up.
No arrow
This is what I bought
Hydro clutch or pmc easy clutch kit? 17 Mar 2020 10:54 #821087
  • Rick H.
  • Rick H.'s Avatar
Rick H.
I kind of put this on the back burner until I was looking for something else. I did some checking and apparently these cable covers are actually called "gaiters". Makes sense I guess because that is what we called fork rubber covers at one time. Anyway if you nose around Ebay and the internet you will find several different types out there.
Also if anyone is contemplating purchasing an Easy Pull Clutch package from Z1- Enterprises they told me they should have them back in stock around the middle of April. Of course that is dependent on Corona 19 to a certain extent.
Rick H.
Rick H.
Hydro clutch or pmc easy clutch kit? 17 Mar 2020 11:08 #821088
  • old_kaw
  • old_kaw's Avatar
  • Thank you received: 269
Clutch cable problems in that area are not from water, instead from im-proper cable routing and exhaust heat. Normal cable lubing should prevent water to cable ingress.
THIS is a cooked cable, fo-sure. lol
1981 Kawasaki Kz1000K1
The following user(s) said Thank You: Scirocco
Last edit: by old_kaw.
Hydro clutch or pmc easy clutch kit? 17 Mar 2020 12:00 #821093
  • gordone
  • gordone's Avatar
old_kaw wrote: Clutch cable problems in that area are not from water, instead from im-proper cable routing and exhaust heat. Normal cable lubing should prevent water to cable ingress.
Your photo is taken to low, the problem is where the wire from the clutch handel goes into the adjuster... not after the adjuster.
Project:
Hydro clutch or pmc easy clutch kit? 17 Mar 2020 12:57 #821099
  • old_kaw
  • old_kaw's Avatar
gordone wrote: I lubed my clutch wirer yesterday, and identify some corrosion after the adjuster midway (with the cylinder 1 exhaust pipe).
These adjuster:
I don't claim to be a rocket surgeon Gordone, but my pic is pretty close to where your pic was taken. Nether pic looks very close to the clutch lever to me.
If water is entering at the clutch lever, there are boots that can be had to cover up that area.
Hydro clutch or pmc easy clutch kit? 17 Mar 2020 14:57 #821108
  • gordone
  • gordone's Avatar
My English is not exact enougf, full misunderstanding here :)
On my cable was water coming in here, please ser picture below, properly from pressure washing?
Project:
Hydro clutch or pmc easy clutch kit? 17 Mar 2020 19:04 #821128
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
If the clutch cable length and clutch acutator get his final adujstment i heat up a shrink tube and seal the non-water proof part.....(easy 2 Cent fix).
