Hydro clutch or pmc easy clutch kit? 17 Mar 2020 22:44 #821136
  • gordone
  • gordone's Avatar
  • Thank you received: 67
Scirocco wrote: If the clutch cable length and clutch acutator get his final adujstment i heat up a shrink tube and seal the non-water proof part.....(easy 2 Cent fix).
Good idea!
Will also protect the paint on the frame.
Project:
Last edit: by gordone.
Hydro clutch or pmc easy clutch kit? 18 Mar 2020 10:20 #821172
  • old_kaw
  • old_kaw's Avatar
  • Thank you received: 269
gordone wrote: My English is not exact enougf, full misunderstanding here :)
On my cable was water coming in here, please ser picture below, properly from pressure washing?
That cable is too close to the #1 exhaust pipe, so anything you may be able to put over it will soon melt / disintegrate from the heat. The heat also burns off any lubricant leaving the unprotected cable to oxidize internally and melts the internal nylon cable liners.
Don't sweat your englaze my friend. You are doing fine. :-)
1981 Kawasaki Kz1000K1
Hydro clutch or pmc easy clutch kit? 18 Mar 2020 13:04 #821181
  • gordone
  • gordone's Avatar
Haha, I need todo something with the routing :)
Project:
The following user(s) said Thank You: old_kaw
Hydro clutch or pmc easy clutch kit? 19 Mar 2020 10:37 #821225
  • old_kaw
  • old_kaw's Avatar
gordone wrote: Haha, I need todo something with the routing :)
I imagine your cable is already cooked like mine was after I installed my SS Delkevic header. (not double walled pipe)
Replace the cable and install a clip right where the cable goes between the #1&2 like my pic shows. BUT, even after cable replacement and re-routing, I think my cable is cooked again. Perhaps a small cable SS heat shield may be in order for this location.
Hydro clutch or pmc easy clutch kit? 26 Mar 2020 11:32 #821829
  • Bulletkz
  • Bulletkz's Avatar Topic Author
  • Thank you received: 18
Just put this on mine . Clip kept turning into the pipe. I am still waiting for the easy clutch to go back in stock.
If it doesn't when I get the time I will do the zx7r hydraulic clutch.
Hydro clutch or pmc easy clutch kit? 26 Mar 2020 11:38 #821832
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1843
Nice clamp Bulletkz. I need to replace my clutch cable it was against the header and melted the outer casing. Nice upgrade. Will you share your source?
Hydro clutch or pmc easy clutch kit? 07 Apr 2020 15:23 #822820
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
For those that may be interested, Z-1 Enterprises sent out a notice that they have the PMC clutch lever kits back in stock.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Hydro clutch or pmc easy clutch kit? 07 Apr 2020 16:53 #822826
  • Mikaw
  • Mikaw's Avatar
Rick H. wrote: For those that may be interested, Z-1 Enterprises sent out a notice that they have the PMC clutch lever kits back in stock.
Rick H.
Thanks Rick H, I jumped on the ball bearing style band wagon. Waiting on a new clutch cable to arrive.
The following user(s) said Thank You: Rick H.
Hydro clutch or pmc easy clutch kit? 08 Apr 2020 07:16 #822862
  • Bulletkz
It's a cheap flea bay chopper style part. Got it in chrome and sanded it down to look aluminum.
Hydro clutch or pmc easy clutch kit? 06 Jun 2020 03:23 #827419
  • calum
  • calum's Avatar
  • Thank you received: 369
Nessism wrote: I had both types when rebuilding my 750 and chose to go with the ramp and ball version which was smoother. It's a little finicky to set up though in that you have to get the ramp in the right position during assembly or there will be no clutch. Going off memory but the arm on the mechanism needs to be at roughly 90 degrees to the cable coming through the cover.
I have been looking into this and the ball and ramp actuator doesn't screw into the sprocket cover rather locks directly into the recess in the cover. I have this cover on my 750:
I can't see how the actuator would fit. Ed, did you use a different cover on your bike?
Last edit: by calum.
