Seal by shift lever
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Seal by shift lever
25 May 2023 08:28
#885175
There is no bushing in the sprocket cover. There are three seals. One in the transmission cover and two in the sprocket cover. One is pressed in from the outside facing out and the other is pressed from the inside facing in. They have to be destroyed to take them out as the the cover is milled to act as a bushing for the lever shaft. The two seals act as support for the shaft. You'll find they come as a set of three in the seal kits.
  • willemZ900
  • willemZ900's Avatar
  • Z1B 4 ever
25 May 2023 08:32
#885176
And not very difficuld to remove and press the New ones in
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 May 2023 08:42
#885177
I bought the whole kit on eBay.
1973-80 z1 z1r kz900 kz1000 kz 1000 motor engine Oil Seal Kit crankcase gasket
  • 29mmgas
  • 29mmgas's Avatar
25 May 2023 10:13
#885184
I’m thinking I’ll do the same because I’m sure everything needs to be replaced. The bike sat a long time! Thanks all for the input.
  • sf4t7
  • sf4t7's Avatar
25 May 2023 10:18
#885185
Z1E also has them.  Part 200-1032, you'll need 3 of them.  Install them as described in Steve's reply.
Scotty
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 May 2023 12:09
#885189
I paid $31.49 with free 3 day shipping. I changed all the seals while I was at it.
  • Wheelhop
  • Wheelhop's Avatar
30 May 2023 07:38
#885402
nice looking bike Jim! When was last time it was on road?
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
  • 29mmgas
  • 29mmgas's Avatar
30 May 2023 17:29
#885431
Hey thanks Jim, 1984 was the last license plate. It’s been sitting in a shed, then move to storage and now it’s in my garage it needs a lot of work. It’s coming along. I hope to have the before and after pic not to long from now.
  • sf4t7
  • sf4t7's Avatar
30 May 2023 21:03
#885444
I guess that's a common story - since 1995 or so my Z1A  sat in a shed, then in kind of damp storage, now it's back home being revived
Scotty
1974 Z1A
Yoshimura 987
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
30 May 2023 22:15
#885451
At least 8 of our bikes were dead to the world when we got them. We have one more bike to go through, an 83' Honda CB 1100F. It's been parked for over 20years. It's very satisfying to bring one back from the dead and ride it.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
The following user(s) said Thank You: sf4t7, gordone, howardhb
