Bike port 17 Mar 2022 13:01 #863932
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2621
Now to move on to the Mags.
Bike port 18 Mar 2022 01:29 #863957
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 632
Steve, I would like your opinion on the color of my plugs...
This is with one-step colder spark plugs, and the RS34 flat slide carbs which will probably stay on the bike for a while.
Have 27.5 pilot jets installed for the mid-40's to 60's air temps currently in W. Michigan.  Will probably drop to 25's when warmer weather arrives.
I'm going to attempt a short ride video with my cell phone camera if I can make that work.
1982 KZ1100-A2
Last edit: by daveo.
Bike port 18 Mar 2022 07:27 #863968
  • SWest
  • 10 22 2014
Try hotter plugs?
Bike port 18 Mar 2022 07:33 #863969
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
My $.02. They look about as good as your going to get. Dry black full circle on the base ring. Nice tan color on the center ceramic. And a color change on the earth strap in the correct spot… Ride it like you stole it!
My only suggestion is to get a magnifying glass and look down inside at the bottom of the ceramic and look for shiny specs. It would indicate detention, if present it actually microscopic pieces of the piston getting exploded off.
Bike port 18 Mar 2022 07:39 #863970
  • SWest
  • 10 22 2014
Mine looked like that at first. The more miles I put on the new bores the better the plugs look.
Bike port 18 Mar 2022 10:28 #863984
  • daveo
  • daveo's Avatar
  • Premium Member
Didn't see that strap color with the standard hotter plugs...thank you zed1015 for the spark plug heat range recommendation.
The ceramic had consistent color from top to bottom, with no aluminum specks visible way down in there.  While I was cleaning carbon off the pistons recently, I saw no evidence of detonation on those surfaces either.
Thanks again
1982 KZ1100-A2
Bike port 18 Mar 2022 11:13 #863989
  • Mikaw
  • Mikaw's Avatar
Chances are the heat range was to hot and the color on the earth strap was either not changing or it was right at the base ring. Either way you wouldn’t see it!
Here’s a good reference.
www.dragstuff.com/techarticles/how-to-read-plugs.html
Last edit: by Mikaw.
Bike port 19 Mar 2022 13:19 #864041
  • SWest
  • 10 22 2014
On to the next project.
Bike port 20 Mar 2022 11:27 #864087
  • SWest
  • 10 22 2014
I ordered a set of bearings last night. I'll use these to balance the tire then change them when they come.
Bike port 20 Mar 2022 14:47 #864094
  • SWest
  • 10 22 2014
I should have the new bearings by Thursday.
Bike port 20 Mar 2022 18:07 #864103
  • Mikaw
  • Mikaw's Avatar
Is there a casting number on the crush drive. It looks similar to the one Mr E was looking for that fits a 77-78 rear spoke with disc
Bike port 20 Mar 2022 19:00 #864108
  • SWest
  • 10 22 2014
If there is it's not legible. There was a ink number followed by a cast one but the ink came off when I tried to clean it. It is smaller that my Z1/KZ900 sprocket carrier.
