Bike port 26 Feb 2022 08:55 #862948
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1866
Steve, I sent you the new set not the used I just recently picked up. The used was untested so I didn’t want to skew any tests with unknown equipment. With the restrictors in you will not see full vacuum. That tool is ready to be used. When testing and adjusting the vacuum value is irrelevant. You’re looking for them to be all as equal as possible. With your number 3 carb fixed you’ll have to adjust 1,2 and 4 to match it.
www.carbtune.com/
The following user(s) said Thank You: daveo, SWest
Bike port 26 Feb 2022 08:57 #862949
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2635
Thanks Matt will do.
Bike port 27 Feb 2022 06:13 #862967
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
Watch Steve's new VM33 Smoothbore carb sync procedural video, coming soon to a widescreen near you!
1982 KZ1100-A2
Bike port 27 Feb 2022 11:55 #862976
  • SWest
  • 10 22 2014
I like these. working on the clip now. Internet is FKing up. I wonder why? NOT
Bike port 27 Feb 2022 16:55 #862992
  • KZJOE900
  • KZJOE900's Avatar
  • Admin
  • Thank you received: 443
Hi Steve, give it a good balancing and record it while you are doing it. I'm sure people here who haven't tried it yet will appreciate a video. I used the carbtune on my KZ when I balanced mine carbs and loved it. I wish it was as easy as Z1 carbs. On he KZ you have to take off the carburetor tops to get at the individual throttle stop screws. At least on the Z1 the stops screws are out in the open. Albeit, still have to have the tank off.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Bike port 27 Feb 2022 17:48 #862993
  • SWest
  • 10 22 2014
Ask and ye shall receive.
The following user(s) said Thank You: KZJOE900, daveo
Bike port 27 Feb 2022 19:12 #862995
  • Mikaw
  • Mikaw's Avatar
You need to adjust pilots again now.
Bike port 27 Feb 2022 19:21 #862996
  • daveo
  • daveo's Avatar
  • Premium Member
And after that, put new sticky grips on...cause Stevie's going to need them!
Great movie btw
1982 KZ1100-A2
Last edit: by daveo.
Bike port 27 Feb 2022 20:16 #862998
  • SWest
  • 10 22 2014
You mean 17.5's and ditch the 20's?
Last edit: by SWest.
Bike port 28 Feb 2022 06:23 #863003
  • daveo
  • daveo's Avatar
  • Premium Member
When #'s 1, 2 & 4 slides were raised to bring #3 down, it affected the air/fuel mix in each carb. The idle-air screws may need a slight adjustment...not sure, but #3 may need the mix leaned a bit, and the others made a touch richer.
Sync check after changing a valve shim, and again after everything settles in...and whenever you feel like it.
1982 KZ1100-A2
Bike port 28 Feb 2022 06:46 #863004
  • SWest
  • 10 22 2014
Tempted to put the 17.5's back in.
Heading into town today and will check the plugs this evening.
Bike port 28 Feb 2022 09:48 #863006
  • Mikaw
  • Mikaw's Avatar
Yes this. Pilot screws…
