1973 Z1 Maui 14 Dec 2021 08:12 #859063
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1865
Correct on the brn/wht, and the dual female brown. Extra not needed. Good for accessories.
www.wgcarbs.com/index.php/using-joomla/e...-categories/89-coils
Here’s the Wired George relay schematic
Last edit: by Mikaw.
1973 Z1 Maui 14 Dec 2021 12:58 #859076
  • MauiZ1
  • MauiZ1's Avatar Topic Author
  • Thank you received: 19
Cool! I may do that.
Melekalikimaka
1973 Z1 Maui 14 Dec 2021 17:28 #859087
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1033
Melekalikimaka
That could be a great song!
1973 Z1 Maui 15 Dec 2021 06:15 #859094
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 615
What is the relay for the coils for? Does it keep the current from going through the handlebar controls?
Z1/KZ ignition switches, and motorcycle ignition circuits in general can introduce voltage drop at the coil primaries, reducing spark energy.
  The relay bypasses the ignition and kill switches, in order to supply full battery power direct to the coils through the NO relay contacts, while still retaining operation of the kill switch.  The harness we developed is plug & play, with no butchering/cutting/crimping of any OEM wiring necessary; we just crimp matching bullet and ring connectors the the relay harness and battery power connections, respectively.  The relay harness can be simply unplugged from the main harness and coil wiring, enabling the bike to be returned to it's factory original wiring configuration in under ten minutes after the tank is removed.
We were compelled during the resto of our '72 Z1, 'The Seven Year _itch', to disassemble an OEM ignition switch to correct an intermittent issue.  The internal construction we found suggests that the design of the rotary contacts was barely adequate, at best, for the current load imposed, particularly on the circuit feeding 12V to the coils.  See our post linked below:
kzrider.com/forum/4-electrical/606810-z-...-and-troubleshooting
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
1973 Z1 Maui 15 Dec 2021 06:52 #859097
  • Move0ver
  • Move0ver's Avatar
  • Thank you received: 56
If this is a restoration that's going to be ridden vs displayed, I'd go with a modern wiring harness.
PMC makes this one:
japan.webike.net/products/1523082.html
it's pricey, but I'll never go back to an OEM harness on an old bike.  I have it on mine and it's been nothing but amazing.
1973 Z1 Maui 15 Dec 2021 07:10 #859098
  • MauiZ1
That really looks nice. I may need to try that.
1973 Z1 Maui 15 Dec 2021 07:53 #859102
  • Move0ver
  • Move0ver's Avatar
here's a write-up I did including lessons learned:
kzrider.com/forum/4-electrical/608400-pm...s-install-and-review
It has an accessory power connection at the headlight too, which is nice.
1973 Z1 Maui 15 Dec 2021 13:53 #859121
  • MauiZ1
The Sohc Hondas suffer from similar electrical issues. I think I will solder up a relay for the start circuit on this Z1, seems like a safe thing to do for increased reliability. Thank you all for the great information.
1973 Z1 Maui 15 Dec 2021 16:20 #859134
  • hardrockminer
I did the Wired George relay addition to my 1980 KZ1000 and it runs perfectly.  I bought a second kit to put on my Z1B but I've never installed it.  Maybe this summer.
1973 Z1 Maui 16 Dec 2021 13:32 #859174
  • MauiZ1
I’m looking over details on the carb hoses.
the bowl overflows gather together and drop down over the back of the motor toward the swing arm.
where do the two 6.5mm bowl vents go besides just up? They are listed as 140mm long in Brookes.
thank you
1973 Z1 Maui 16 Dec 2021 13:38 #859175
  • MauiZ1
On another note
i am trying to get a machinist friend of mine to make me a set of the nylon choke plunger collars. If he is interested I may try to get him to make more of whichever style someone needs, would any of you be interested?
1973 Z1 Maui 16 Dec 2021 16:37 #859180
  • hardrockminer
No eBay APP ID and/or Cert ID defined in Kunena configurationYes, just up...towards the front of the air intake.  On later models there is a hole in the brace just in front of the airbox where I put the ends of mine.
Can you flash a photo of the nylon choke thingys?  I think yours are different from later versions.  But if not, there are several people selling new ones on ebay.
Search this part number on ebay.  293416898481
Last edit: by hardrockminer.
