Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 14 Jan 2020 16:22 #817081
  • foxkawa
  • foxkawa's Avatar Topic Author
  • Thank you received: 6
Hi!
My name is Jan and i live in Sweden.
In november i bought mysel a Gpz750 1982 who had seen his best days.
I started the same day to take the Bike apart , most of the parts was junk but that doesn´t bother me becuase i should only use the frame engine and the electrical wiring..
First of all i bought a fork and a swingarm complete with rims from an zrx1100.
The fork was just bolton.
The swingarm i had to shave of 5mm and i also made som adapters so i could use smaller bearings so the oem swingarm bolt fit.
Bought a 3/8" offset front sprocket and shaved off the wheel hub 9mm so the sprockets got in line.
Last edit: by Street Fighter LTD.
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 14 Jan 2020 18:32 #817087
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Thank you received: 1972
Welcome to KZRider
I fixed your pictures so all can see them easily
Next time hit the insert all tab and your pictures will be full size
The following user(s) said Thank You: foxkawa
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 14 Jan 2020 18:52 #817089
  • Skidmark
  • Skidmark's Avatar
  • Thank you received: 260
Welcome, Jan! Looking forward to seeing your progress with your bike. I am building a KZ750 with similar colors to the ELR, but more of a race flavor resto-mod.
Retired gearhead
'81 KZ-750 E2
'87 Suzuki Savage 650 Street Tracker
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 14 Jan 2020 21:17 #817094
  • scubaanders
  • scubaanders's Avatar
  • Thank you received: 233
Nice to see that you are making progress Jan. Nice that you was able to score a ZRX swingarm, pls post more pix.
/Anders
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 15 Jan 2020 02:34 #817099
  • foxkawa
First of all i strippe,d the whole bike and sanded it, and then i cut away all brackets on the subframe that shouldn´t be in use. Painted the frame and engine in gloss black.
The best thing with this bike was that the engine was renovated but the rest of it was crap.
I don´t have any pics of this.
The zrx swingarm i got from crooober for a cheap price, thr fork from germany and the wheels i bought here in Sweden.
Attachment not found
Last edit: by foxkawa.
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 15 Jan 2020 02:38 #817100
  • foxkawa
On Ebay i find these calipers and discs. Put a radial master cylinder on also.
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 15 Jan 2020 02:40 #817101
  • foxkawa
Took some exhaust wrap and winded the headers.
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 15 Jan 2020 02:46 #817102
  • foxkawa
I find this speedo on ebay. It has digital showing on speedo but with speedocable, pretty easy to install except for the wiring diagram who was in chinese. But when i got it translate it was plug and play :-)
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 15 Jan 2020 07:34 #817114
  • foxkawa
The handcontrols from zrx1100 is almost bolt on. You just need to change places of the cables in the connectors then it all work fine. It is twenty years between the controls but the cables has the same colour in the controls.
I also bought a little rear view camera and a monitor, just for show but it works fine.
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 15 Jan 2020 07:41 #817115
  • foxkawa
With the zrx swingarm the suspension will be wider then stock so i. The new shocks had 14mm ID had two bobbins for the swingarm and drilled a larger hole so it fits the upper shock bracket. The new shocks has 14mm bushings so i took a tube who had m10x1.25 inside . I turned off the outer diam from 20mm to 14mm except for 3mm . Now i have a nut that fits perfect in the upper hole on the shock.
Sorry for my english ;-).
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 15 Jan 2020 07:42 #817116
  • DoctoRot
  • DoctoRot's Avatar
  • Thank you received: 664
you got my attention! cool project.
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 15 Jan 2020 07:43 #817117
  • foxkawa
I also bought the mikuni rs carbs.
