Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 26 May 2020 23:30 #826629
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
Hi Jan, nice bike my friend, it looks great.. If you still have the stock gpz750 front end, would it be possible for you to measure the length of the steering stem please, just from the top of the bottom clamp bearing surface to the top of the bare stem, if that's at all possible ?.... Thanks
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 27 May 2020 00:44 #826631
  • foxkawa
  • foxkawa's Avatar Topic Author
  • Thank you received: 6
GPZenthusiastic wrote: Very nice bike!
Lot of work involved.
Are those rear shocks from a zrx like the swing arm?
No the shocks are aftermarket ones. :-)
The following user(s) said Thank You: GPZenthusiastic
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 27 May 2020 01:40 #826632
  • foxkawa
750 R1 wrote: Hi Jan, nice bike my friend, it looks great.. If you still have the stock gpz750 front end, would it be possible for you to measure the length of the steering stem please, just from the top of the bottom clamp bearing surface to the top of the bare stem, if that's at all possible ?.... Thanks
Sorry but i haven`t the old fork left. But if you wonder about the zrx fork i have so is it exactly the same measurment and bearings. Easy replacement, just bolt on.
The following user(s) said Thank You: 750 R1
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 27 May 2020 01:59 #826633
  • 750 R1
  • 750 R1's Avatar
Thanks Jan. I'm doing a front end swap and I actually have a 750 R1 front end but its still on the bike, I don't want to remove it yet because I still have to move the bike around. I'm in the middle of getting my replacement front ready to bolt on and haven't yet sorted out what I'm going to do about a steering stem, I'm thinking about lengthening the donor stem {its off a 2000 Triumph 955i speed triple, 45mm showa forks}, that's why I asked about the length of the stock stem. Never mind, I'll get it sorted.... Thanks anyway...
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 29 Jun 2020 14:53 #829363
  • GPZenthusiastic
  • GPZenthusiastic's Avatar
  • Thank you received: 7
Did you check top speed with a reliable method by any chance ?
I haven't found any information in that regard based on a GPS for example.
My bike has the stock engine with 11+ k miles and I want to be sure I'm getting all the potential from factory since I had to change front and rear sprockets.
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 29 Jun 2020 15:19 #829372
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
Top Speed checks in Sweden could be very, very expensive. He have to take a ferry to Germany were i live to do a top speed ride steet legal.
Check the Video of a La Ferrari Driver from Spain on German Highway :
Last edit: by Scirocco.
Gpz750 1982 will be a Eddie Lawson replica. Almost :-) 29 Jul 2020 09:05 #831794
  • kzr750r1
  • kzr750r1's Avatar
  • Thank you received: 9
Nice to see the ZRX swap working on an KZ750R1. Thanks for sharing your build!
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
