1974 kz trike 30 Apr 2021 21:05 #847803
  • Shankkole
  • Shankkole's Avatar Topic Author
  • Thank you received: 141
The oil pan was gouged bad, so I added some detail with rotary cutter on a dremel.
1974 kz trike 01 May 2021 05:48 #847811
  • Bent Trigger
  • Bent Trigger's Avatar
Dang!! Looks like a road grinder!!   It slices, It dices, I does virtually anything!! Chris
The following user(s) said Thank You: Shankkole
Last edit: by Bent Trigger.
1974 kz trike 01 May 2021 11:54 #847828
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1859
Did you watch Mad Max recently?
1974 kz trike 01 May 2021 17:18 #847849
  • Shankkole
HaHaHa                 It is not as sharp as it looks.It really catches the light but it will be buried down low.It may add some cooling, but its more for shine.I forgot to order the 18mm o ring for between the cases, so I'm on hold for now.I got a Dyna S setup with new coils and wires and the carb gaskets in the wind.Also The icelandic sheep hide from Canada is heading my way.Oh Yeah its coming together. Im leaning Chrome molly for the Drag bar if $ allows and polish, Or it will be black tube after I raid some friends cut off piles if I'm out of cash, which aint far away, hahahaha.   I liked it when I bought it, But I love what I have built, I might tear up when she starts again.
The following user(s) said Thank You: Bent Trigger, Dragbike_Mike
1974 kz trike 04 May 2021 16:24 #848008
  • Shankkole
It costs me some lunch money, But check out this GEM              I can't get the pics bigger, but its a NOS Henry Abe air filter in original box and I'm hoping the boots are as good as described, we shall see.
Last edit: by Shankkole.
1974 kz trike 04 May 2021 16:38 #848009
  • Bent Trigger
I had one on my chopper but it burnt to a crisp!! Your gonna love the look!! Freakin Bread Box Baby!!
1974 kz trike 04 May 2021 22:13 #848017
  • RBRKZ
  • RBRKZ's Avatar
  • Thank you received: 29
Reminds me of the wild beauties in Street Chopper magazine a long time ago.  I'd would be looking for "paint by Molly" if I saw this one in a 1971 magazine.   I really like this project a lot.
1974 kz trike 07 May 2021 11:49 #848171
  • Shankkole
The BREAD BOX is in and truly NOS. I almost shouldn't use it by I will. Super Groovy mood on friday for this guy! gonna put the box up on a shelf for sure.
1974 kz trike 07 May 2021 16:53 #848187
  • 750 R1
  • 750 R1's Avatar
  • Thank you received: 394
That's a rare bit of kit, I see its for a CB750, they have a different carb spacing than the Kawasaki, you used to be able to buy rubber manifolds to put VM29 smoothbores on Honda 4's, I've never seen manifolds for Honda spacing on Kawasaki's...
1974 kz trike 07 May 2021 17:34 #848191
  • Shankkole
From what I have read on old rags is they are spaced for the KZ and they have different boots for the CB that have another angle to make this spacing work on the CBs . I will make a new backplate easily if needed to correct carb spacing.
1974 kz trike 07 May 2021 18:49 #848195
  • 750 R1
  • 750 R1's Avatar
I can't remember all the details, I had one of these on a Honda 4 in the early 80's, good job finding one it that condition !  They actually worked way better than pods...
1974 kz trike 08 May 2021 07:50 #848209
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 517
Hey Brad! These were $19.99 in the mid 80's! The Bread Basket!
