I found a old turbo drag bike
- DoctoRot
Re: I found a old turbo drag bike
10 Jun 2021 14:37
Steve - the earlier stator cover doesn't fit the MKII.
Nice work. We need more pics!
The following user(s) said Thank You: thebuelligan
- thebuelligan
10 Jun 2021 14:53
@swest MK2 crank and stator are totally different and early cover won’t fit ..
if it had only been that straight forward lol
10 Jun 2021 15:05
That's right. The cover would bolt on but the innards are different. My bad.
Carry on.
Nice work
Nice work
- thebuelligan
21 Jun 2021 15:37 - 22 Jun 2021 13:38
Started with getting hold of the old drag bike at the beginning of this thread that was for sale here in the UK and now here it is 8 years later!! Lots of changes but fundamentally the same old drag bike but now registered and back on the road....
Last edit: 22 Jun 2021 13:38 by thebuelligan. Reason: to add detail
The following user(s) said Thank You: DOHC, Scirocco, Bent Trigger
- thebuelligan
16 Jul 2021 18:45 - 17 Jul 2021 05:49
Last edit: 17 Jul 2021 05:49 by Street Fighter LTD.
- DOHC
- Those Doe-Hawks really go!
16 Jul 2021 20:19That's a good number. Can you post the curve so we can see where the power is. How much boost were you running?First Dyno session! Still some work to do
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- thebuelligan
17 Jul 2021 02:13 - 17 Jul 2021 05:50
10psi on the 196 with the old F40 Rayjay with the original bendix zenith. Some work to do on the fuelling bottom end and mainly want to figure out where I am with the ignition timing as this was an initial “ guess” Got no plate on the vertex so unsure of advance at the moment. Will set the initial static up and take it from there
Last edit: 17 Jul 2021 05:50 by Street Fighter LTD.
17 Jul 2021 05:52
Good numbers.
I fixed your pictures
PLEASE next time click the insert all tab to complete the process
17 Jul 2021 09:18
What are the particulars in your setup ?
What fuel ? Carb ?
Water or alcohol injection ?
Pistons specs ?
cams, headwork ?
Plugs ?
Planning on Nitrous ?
What fuel ? Carb ?
Pistons specs ?
cams, headwork ?
Plugs ?
- thebuelligan
17 Jul 2021 16:57 - 17 Jul 2021 17:00
Running original RC engineering turbo plenum, headers and wastegate with a Rayjay F40 turbo. Carbs an ATP Bendix with added Thunderjet circuit running 4psi fuel pressure
No water or Alcohol injection but have a vintage ATP unit I might fit
Sunoco Maxnos 119 fuel
Stock 900 hollow cams with flowed head standard size valves
Plugs are NGK B9ES
Nitrous is fitted and ready to go!
Basic motor details are -
Motors built around early 73 cases
all balanced and blueprinted
MK2 Crank welded and balanced
APE Main bearing support and crank bolts
5qt full deep sump modded pump
Vertex magneto ignition Taylor made leads
MRE gearbox billet second gear
windage tray
1327 MTC big block with modified stepped liners and 7.8:1 turbo pistons (Needed lots of balancing)
Flowed and ported head
Stock cams with slotted sprockets
Liska Cam chain gears
Stainless valves Underbucket shims Ti spring retainers
APE studs and head bolts
MRE lockup clutch with standard plates and springs
APE clutch mushroom with PMC easy actuator
Plugs are NGK B9ES
windage tray
Last edit: 17 Jul 2021 17:00 by thebuelligan.
The following user(s) said Thank You: DOHC, Street Fighter LTD, Dragbike_Mike
- thebuelligan
17 Jul 2021 17:07
17 Jul 2021 17:21
Looks like you are well on your way to having a real runner.
250 HP is a very easy safe bet. before the nitrous hits
I changed mine over to the Mikuni 42mm flat slide some years ago and I find it to be a winner.
