The KZR750R1 Return to life 08 30 Sep 2008 19:05 #239553
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
  • Thank you received: 13
The ZRX passenger pegs have a nice bow cast into them, so you can attach them and they bend around the rear shock body. I just have to figure 'where' to mount the pegs in relation to the rear shocks and in a location that will be comfy for the wife. Now, with passenger pegs located I can trash the heavy original foot-pegs and source some rear-set foot-pegs. After the pegs are located I can re-route the exhaust in a way that will improve ground-clearence. Also, the ZRX pegs have a hanger-bracket cast into the right peg bracket...convenient. ;)
-KR
PS> love your bike, too!B)
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
The KZR750R1 Return to life 08 01 Oct 2008 22:13 #239754
  • kzr750r1
  • kzr750r1's Avatar Topic Author
  • Thank you received: 9
The method of attachment will be new tabs attached to the frame. All similar to the units that hang the new master cylinder. As Bad Kaw mentioned there set up pretty well for the KZ as the ZRX is the modern knock off... The only thing I'm concerned about at this point is the peg angle after, But some of that can be fudged depending on how it's mounted.
Funny as I (in a weak moment) considered putting the old HW back on just to have a solid bracket for the pip hanger.
Not going to happen...
Almost drove by one of my favorite salvage yards Tuesday on the way to work. Resisted the temptation. I can wait on this for now. Noone except for the kids are interested in riding with me... Not having these on board is giving me a nice excuse.
Since I'm not going to buy anything in the near future I'll pull it out and show off where I'm at with the project. One item I took some grief for on the old forum is fixed. That will be a supprise...
Other items are documented over there but they are not on this forum so worth a revisit at some point.
Check with you guys later.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
The KZR750R1 Return to life 08 05 Oct 2008 22:23 #240330
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
Lookin' forward to the pics!
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
The KZR750R1 Return to life 08 06 Oct 2008 07:04 #240367
  • babyELR
  • babyELR's Avatar
  • Thank you received: 0
I've done a lot of easy mods to the bike so far, still need to install the stainless brake lines though. The hydraulic clutch conversion was the latest. So much smoother than a cable. Haven't dove in to anything to deep yet like swingarm or forks though. I am considering it, but not sure if I have the talent or tools to pull it off. Nice to know I can come here to figure everything out if I decide and try. By the way, how much work was it to swap in the ZR engine?
current bike:
1982 GPZ-750
past bikes:
1978 Z1-R
1982 KZ-550, 615 kit, cams, head-work
1978 GS-1000 drag bike (younger days fun)
The KZR750R1 Return to life 08 06 Oct 2008 17:39 #240450
  • kzr750r1
Well the motor swap was done when I could pay for help. No wife no kids and living in an apartment.
Spacers were placed at most all the mount points to use the existing GPz/KZ750R1 hardware. Mount points were brought in on the ZR case. Many items are the same between the two bikes. Transmission has the same gear ratio, compression is the same and many other similarities. I'm using the '82 base pan on the '91 motor for example. On this install chose a Canadian valve cover to rid myself of the emissions valve assembly.
Some updates were nice... Since you mention the clutch. The cable is attached to a cam lever on the right side. No more push tube running through the case.
I'm thinking of placing the GPz cams in the unit this winter see if I can get the motor to liven up a bit. In all I should have had the old carbs prepped for this motor as what I'm using is way over kill... I need to beef this thing to an 810 to get some use out of them.
Well see. If I can I'll take some more detailed pictures but our good camera is without the utility lens at the moment. Hard to take detail pictures with a 200mm zoom. :)
The KZR750R1 Return to life 08 06 Oct 2008 18:37 #240463
  • Bad Kaw
  • Bad Kaw's Avatar
  • Flying Squirell
Got pics of your hydraulic clutch conversion???
If you do, make a new post (here in 'Projects'...) I'd hate to thread-jack this one as it's a good 'un.
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
Last edit: by Bad Kaw.
The KZR750R1 Return to life 08 06 Oct 2008 20:33 #240496
  • kzr750r1
Please do I'd like to see that too... And now for the pictures promised earlier...
Full bike shot.
Last edit: by kzr750r1.
The KZR750R1 Return to life 08 06 Oct 2008 20:38 #240498
  • kzr750r1
There are so many little details that it's hard to choose what to show. Here is the motor mount on the front. The others are buried so hard to get photos without removing covers or lifting the bike.
The KZR750R1 Return to life 08 06 Oct 2008 20:41 #240500
  • kzr750r1
Screwed this one up trying to post multiple pictures. DOH!
The KZR750R1 Return to life 08 06 Oct 2008 20:48 #240502
  • kzr750r1
Oil Cooler detail. Zeypher Oil Cooler with AN bungs welded in instead of the stock hose fittings.
How the hell do you get mulitple pictures on one post!
The KZR750R1 Return to life 08 06 Oct 2008 20:51 #240503
  • kzr750r1
Kick stand and left rear set.
The KZR750R1 Return to life 08 06 Oct 2008 20:53 #240504
  • kzr750r1
Front end shot side.
