z1r engine noise
  • z101mike
  • z101mike's Avatar Topic Author
z1r engine noise
07 Jul 2017 19:54
#766362
can the cam chain tenisoner be removed with no problems (stuff fall in side engine?)wow my verification just expired while tiping
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: z1r engine noise
07 Jul 2017 19:56
#766364
Why would you want to remove it?
  • z101mike
07 Jul 2017 20:15
#766367
I know the carbs need sycronized
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Jul 2017 20:18
#766368
If you remove it don't turn the engine. What does that have to do with the carbs?
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
07 Jul 2017 20:32
#766370
z101mike wrote: I know the carbs need sycronized
Sleep on it and take a fresh look in the morning...you might be surprised to figure out the problem in the midst of a dream. :)
1982 KZ1100-A2/1170 sleeper 😀
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • z101mike
07 Jul 2017 20:39
#766373
It has 8455 miles so I would think it wouldnt be piston slap
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
07 Jul 2017 20:44
#766375
If you have a full service manual check the procedure to tighten exhaust manifold when its cold in the morning,Not when its hot
The following user(s) said Thank You: z101mike
  • z101mike
07 Jul 2017 21:01
#766377
this thing runs like a scolded ape,back tire breaks lose at 50mph with a twist of the grip, in 3 gear felt like i was on ice.the kawasaki dealer that owned this bike did a lot to the engine before my brother got it.he painted pro/street on the back fender and I believe it
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
08 Jul 2017 00:28
#766386
Would be interesting to know what modifications have been done - spinning the tire in third with throttle only is way above stock Z1R performance, even for the Z1R-TC. What RPM does it run at 60 mph?
How about posting a half dozen or so of pics for us? If it isn't turbo, then it is likely min. 1260 cc for that level of power.
-Scott
  • z101mike
08 Jul 2017 06:07
#766392
My brother bought this bike from a dealer in los vegas in 82 and was told that the motor had hotter cams weisco big bore kit 1200 i think and the head had been ported.It is not the turbo bike.
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Jul 2017 06:17
#766394
I asked some pertinent questions but no answers. :unsure:
