Fiberglass Help
- quadsheavn
Fiberglass Help
11 Nov 2005 08:57
Y'all were such a big help with my frist body work project, I was hoping you might be able to help me again
I have been asked to fix an outboard motor cover, and its all fiber glass. I know its not a bike, but...
Now I know i can work with bondo and sand paper, and I am pretty good with a rattle can, but fiberglass. Thats a whole new ball park for me.
Missy
Missy
- ronboskz650sr
Re: Fiberglass Help
11 Nov 2005 09:09
Do you have a picture of the damage? That will help with the method of repair.
- quadsheavn
Re: Fiberglass Help
11 Nov 2005 09:21
Nope no pics yet. I just got the call from the Mounted Patrol this morning. I need to go pick the cover up here in a while.
But I was told it has a crack, and is all scuffed up and in really sad shape.
Will post pics as soon as I get it.
Missy
Missy
- KzJim
Re: Fiberglass Help
11 Nov 2005 09:41
I have worked in a 'glass' shop before.. and we did repair stuff... if its cracked it needs to be reenforced from the back with 'cloth' and make sure you have at least 2" around the crack... make sure you clean the area really good.. and saturate the cloth really well... use a paint brush to work it in.
the gel coat can be sanded and filled with the green body filler...and primered, and be sanded out.... the red will shrink away from the gel coat.
dont mix the resin and hardner to hot.. or it will burst into flames (guess how i know this?) mix it in a 1/2 gallon milk container.. when your done.. let the excess harden and thro it away...
Good luck
Good luck
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
- ronboskz650sr
Re: Fiberglass Help
11 Nov 2005 09:45
Missy, check your U2U. Very similar to what he just said. Just finished it.
- indykaw77
Re: Fiberglass Help
11 Nov 2005 10:57
Burst into flames, huh??? I'll bet THATS a good story!!!!!!! Oh to have been a fly on the wall....
Kawasaki Motorcycles...because cars lean th wrong way!
- ronboskz650sr
Re: Fiberglass Help
11 Nov 2005 11:43
I used to smoke...now I only burst into flames a little.
- KzJim
Re: Fiberglass Help
11 Nov 2005 14:13
indykawi.. ya it was quite an experience.. there is a fine line between mixing hot and mixing TOO hot.... first you feel the heat it generates, then it will start to smoke... when it smokes is when you know your gettin close.. heave smoke.. and your in trouble.. then Poof.. up in flames....:pinch:
it usuall happened when we were in a hurry to get parts laid-up, cured and out of the molds in a hurry.
- quadsheavn
Re: Fiberglass Help
11 Nov 2005 15:00Please Log in or Create an account to join the conversation.
- ronboskz650sr
Re: Fiberglass Help
11 Nov 2005 15:15
You have your work cut out for you. Do all the backing first, after cuting that big crack at the bottom so you can put things back where they belong. After the inside is shored up, just go at the outside the way you did your tank...just using different materials. You'll probably surprise yourself at how quickly it goes. Keep us posted! Oh, I see that's duct tape..whatever, and the metal strip above...just get rid of anything that's holding it together, so you can fit the parts up.
Post edited by: ronboskz650sr, at: 2005/11/11 18:16
- quadsheavn
- ronboskz650sr
