Fiberglass Help
  • quadsheavn
  • quadsheavn's Avatar Topic Author
Re: Fiberglass Help
12 Nov 2005 06:50
#7895
I just looked at the cover a little harder, and I think the only thing holding it together is the duct tape and all the screws. Yikes!
I think maybe I did to good of a job on Bens tank :laugh:
Missy
Post edited by: quadsheavn, at: 2005/11/12 09:54
  • KzJim
  • KzJim's Avatar
Re: Fiberglass Help
12 Nov 2005 15:05
#7932
MAN.. that things rough... I'd almost call it a loss... but give it a shot... it can only get better fron there. be paitent fitting the cracks back to gether... and things sould turn out ok... get yourself some of those spring clamps to help hold it together while you work on it.... good luck!
BTW.. make sure you get all the 'glue'? stuff off... down to the glass or the resin wont stick to it
Post edited by: kzjim, at: 2005/11/12 18:07
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
  • quadsheavn
Re: Fiberglass Help
12 Nov 2005 17:47
#7948
Yeah I am going to give it a go, and see what happens. I cant make it look any worse then it does now. Its all up hill from here.... hopefully :laugh:
Missy
  • Kawozaki
  • Kawozaki's Avatar
Re: Fiberglass Help
19 Nov 2005 09:11
#9014
True Dat! Good God Gertrude!!! What a mess...But I'm sure you will prevail---Show some 'after' pics when you're finished.
good luck,
Oz
  • John68
  • John68's Avatar
Re: Fiberglass Help
19 Nov 2005 11:26
#9026
I hope you are charging whoever for your labor.
A job like that, easily could be 9 hours to prime, 14 hours total.
9 @ $42 = $378 bodywork
5 @ $38 = $190 prime/refinish
5 @ $21 = $105 materials
***********$673
And that's a low estimate for something like that.
You could justify $800+ for a piece in that condition.
  • twin_rotor
  • twin_rotor's Avatar
Re: Fiberglass Help
19 Nov 2005 14:44
#9043
***********$673
Heh... Too bad this is a donation..
The whole boat was donated to a county run search and rescue. My wife was asked to see what she could do with it after the "man in charge" saw what she did with my bike. She has a soft heart... :D
If it was me, I'd stick it to em! :P
Ben
Post edited by: twin_rotor, at: 2005/11/19 17:45
-Ben-
1983 KZ1100A3
  • quadsheavn
Re: Fiberglass Help
23 Nov 2005 04:44
#9777
[/quote]
What can I say
Missy
Post edited by: quadsheavn, at: 2005/11/23 07:45
  • quadsheavn
Re: Fiberglass Help
26 Nov 2005 07:16
#10295
I would like to ask anyone that has had experience with fiberglass repair for some help.
I really tore into the cover a few days ago, and after I got all the old uncured bondo off it, I started to sand the cracked areas. I know that I need to sand it down in the cracked areas, but do I want to open up the cracks and sand them smooth?
Also, what would be the best way to get clue off? The inside of the cover had foam padding glued in, and I have tried a heat gun thinking it would soften it some.. It did not help any. Then I tried a blade, and that just took the hard edges off.
Any help you gentlemen would be willing to share would be wonderful.
Missy
  • indykaw77
  • indykaw77's Avatar
Re: Fiberglass Help
26 Nov 2005 07:59
#10303
For the glue.....try "Goo_Gone" or MEK. OR...if you got a paint/body jobber around....some "real" adhesive remover. I know 3M makes some and it works REALLY well. OH!....and a good putty knife for scraping the yuck off......Good luck.
Kawasaki Motorcycles...because cars lean th wrong way!
  • GargantuChet
  • GargantuChet's Avatar
Re: Fiberglass Help
26 Nov 2005 08:41
#10319
Missy,
I don't know much about fiberglass, but I'm pretty sure that when it's made originally, each layer is put on before the last one has dried. This lets the layers chemically mesh together, so that they adhere.
I wouldn't sand ANYTHING smooth that I wanted the fiberglass to stick to. Since the existing fiberglass is dried, the new stuff won't settle into it chemically. The more surface area you have, the more chance you'll have for mechanical adhesion. A smooth surface won't have enough surface features to hold onto the new stuff very well, so you need to really rough it up to get a good bond. Consider the grittiest sandpaper you can find, or even a rough file.
  • KzJim
  • KzJim's Avatar
Re: Fiberglass Help
26 Nov 2005 13:53
#10374
get all the paint/goo and what else is on there off... use about a 60 grit to rough up the area to be fixed.. you can trim the cracked area if needed to get the cracked area to fit together properly.. 'glass dosent break clean.
like i mentioned in my first post.. start with cloth 'glass to reinforce from the back .. if you have gaps.. take 'chopped mat' and shred it up and fill the gaps. build up the front area with resin.. so it can be sanded and shaped.
make sure there are no air bubbles in the new areas..
www.jamestowndistributors.com/to;ID;,Fiberglass
  • hwms
  • hwms's Avatar
Re: Fiberglass Help
26 Nov 2005 14:08
#10376
One other item that has not been discussed is tempeture.
I have done a considerable amount of fiberglass work and have found that the ambient and/or artificial temperture will affect the quality of the work, IE: the ideal tempeture appears to be 65/70~. If too cold the resin will not set properly and the cloth may not adhere to the previous layer. If too much over 70~ the resin may set so rapidly that it is difficult to properly work the cloth and/or matting. However, in either case the mixture of resin can be adjusted, somewhat, to compensate for these problems.
Harry
