z1 side cover swap
  • jordan
  • jordan's Avatar Topic Author
z1 side cover swap
12 Jan 2015 17:03
#658522
Hey everyone im back from the dead! quick question for you all. I have a buddy who is looking to put z1 side covers on his kz900. Do they fit easily if you cut and relocate the tabs? I was assuming the frame around the side cover area was similair on a z1.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • floivanus
  • floivanus's Avatar
Re: z1 side cover swap
12 Jan 2015 17:23
#658524
Have to make/or buy z1 rear motor mounts for the front tabs, then consider none of the other tabs are likely in the perfect spot, but may be close; then you need a different airbox or *gasp* pods.
Z1 rear motor mounts go for decent coin on ebay though. You also may need to figure a way to mount the bracket for the battery box, i know on 1000s thats part of the motor mount
Past; 78 kz1000, 83 kz550
Andrew
  • jordan
12 Jan 2015 18:02
#658531
No eBay APP ID and/or Cert ID defined in Kunena configurationThank you very much for the reply, I was unaware that the rear motor mounts were one of the mounting tabs on a z1! Is the motor mount a side cover mounting tab on both the left and right sides? I found this online but it looks like just the LH side has provisions for a side cover?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • floivanus
12 Jan 2015 18:32
#658536
Yeah both sides are side cover mounts, last set i saw on ebay went for $40-$50. I had a right side and made my left side from some plain kz1000 ones,
Andrew
  • KZ802
  • KZ802's Avatar
12 Jan 2015 18:49
#658537
floivanus wrote: Yeah both sides are side cover mounts, last set i saw on ebay went for $40-$50. I had a right side and made my left side from some plain kz1000 ones,
I'm planning on doing this swap on my 1978 1000 too once I get some other things out of the way first. You say you made your left side mount from the stock one? could you have done that with the right side as well? This post caught my eye since it's a problem that I will need to solve sometime. It's gonna be -5 here tonight though so I'm trying to solve it on the computer not in the garage!
1980 KZ750 LTDx2
1978 KZ1000 LTD
1976 KZ900 A
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Jan 2015 18:52
#658539
Why would he want Z1 side covers unless they look better with "Gasp" pods? They do fit around them nicely.
  • jordan
12 Jan 2015 19:03
#658540
swest wrote: Why would he want Z1 side covers unless they look better with "Gasp" pods? They do fit around them nicely.
Because nothing looks better than a brown 74 z1 :P
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Jan 2015 19:15
#658543
When Jerry, our Governor, was running for election 30 years ago, the opponents slogan was "If it's Brown, flush it". I like blue. :woohoo:
  • floivanus
12 Jan 2015 20:12
#658549
Yeah i might do the right as well so i dont have to use a real z1 part, if i remember i will put up a few pics
Andrew
  • floivanus
17 Jan 2015 18:36
#658930
Did the other side, just a triangle piece of 1/8" plate and a piece of 16 gauge with a 5/16" or so offset and a 5/8" hole in it, next to it is the z1 item, notice there isnt a bracket for the battery box to mount to on it
Attachment image_2015-01-18.jpg not found
The offset is there to clear the side cover. On the 80 ltd the left side kind of mounts up ( the seat lock is kind of blocked though), the rear mount on the right side rear mount needed re-located, so on one side, two mounts line up and you need to fab the third or waste z1 parts; and the other side one mount is there. So half the mounting tabs are close enough
Andrew
  • SWest
  • SWest's Avatar
  • 10 22 2014
18 Jan 2015 05:49
#658963
I used to have 2/1 pods on my Z1. The lines flowed well with the stock covers but I didn't like the empty space below them and you could see the bottom of the battery. I always liked the Z1R side covers and how they covered so I bought some used and adapted them to my bike. There was no place for the bottom tang. One very windy day one flew off. I didn't notice it until I got home. I was mad enough to chew "Neutronium". I bought a aftermarket one but the they weren't exactly the same. You can see the screw heads but WTF, better than nothing. The other side was stolen while I was in a Pizza joint waiting for my son to get off the bus. I almost caught the little PUKE that took it and I know who he is. I have the patience of an oyster and one day he will fall down a lot. That is if he stays out of jail long enough.
The aftermarket covers won't blow off like the stock ones and I've learned to like them for that reason.
  • etbike3135
  • etbike3135's Avatar
18 Jan 2015 06:10
#658965
Ok, so if you can get the side covers on do the seat locks line up?
1973 Kawasaki Z1
18 years in dragbikes
