My rattle can work
- Jerod
My rattle can work
16 Jan 2013 16:03 - 16 Jan 2013 16:09
I did some rattle can painting on my 650's tank. I wanted to prove that I could do it. I think it turned out pretty well in the looks department, though no one seems willing to comment on whether the paint will stick around after the first fuel dribbles.
I took it completely down to bare metal. Used some filler in a couple spots that I didn't have the tools to smooth. Coated it in 2 medium coats of etching primer. 2 very light coats of Rustoleum engine enamel, and 1 coat just shy of running. 4 progressively lighter coats of U-Pol clear. Basically an entire $20 can of spraypaint. Hours of wet sanding and rubbing compound. And some beers.
A couple shots of different angle in different light. Tell me what you guys think. And let me know if this was all an effort in futility. I used the engine enamel/u-pol on the logic that engine enamel should be resistant to petroleum, and u-pol claims 2k durability in a spray can.
Attachment IMG_2581.JPG not found
Attachment IMG_2582.JPG not found
Attachment IMG_2584.JPG not found
G.I.G.O.
1977 KZ650 C1 - Needs help.. almost as badly as I do.
2005 ZX10R - This one will probably kill me someday.
Last edit: 16 Jan 2013 16:09 by Jerod. Reason: Captcha fail ruined attachments. I hate captchas.
- gengomerpyle
Re: My rattle can work
16 Jan 2013 16:24
wow that does look good, but im not to sure about what will happen when gas gets spilled on it.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- wireman
16 Jan 2013 16:34
Send OMR a pm hes got the inside scoop on what clear to use with the spray bombs
- pete greek1
16 Jan 2013 16:48
It sure does'nt look like rattle can job, hope it holds up for you !!!
- KZJOE900
- Administrator
Super Users
16 Jan 2013 16:57
Looks great! Very high quality looking job. They do claim that it has 2K performance. But no specifics. I think that even 2K urethane is only fuel resistant and not fuel proof. Which I take to mean as long as you wipe it of quickly in case of spillage and not let it soak in fuel. However, although I have used 2K myself, I am extremely careful when I fill up.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- xib71
- Jerod
16 Jan 2013 17:48
I appreciate all the kind words. Still have to get the side covers and tail piece to match. They're currently pretty rough because I was impatient and overly aggressive in the original paint removal. I tried using the same aircraft stripper I used on the tank. When I didn't get the same results, I left it on longer. That didn't work fast enough, so I left it on even longer, and in the blazing sun. That sure did the trick. Nearly ruined the plastic too! There's a lot of pitting that had to be skimmed, results were less than stellar. The rest of the project is still looming over me. I need to have a fresh go at the plastics, but I'm still almost a year away from getting to come home, so everything is on hold unless I farm out the work.
G.I.G.O.
- ramtough_63
16 Jan 2013 18:02
great job man jusat take your time get you some spoy putty dries real quick and can sand out the very small pits
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- 4TheKZ1000
- rstnick
16 Jan 2013 19:45 - 16 Jan 2013 19:45
Nice work!
Waxing the paint I believe will help protect it from gas spills.
Not full proof, but does add a layer of protection.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 16 Jan 2013 19:45 by rstnick.
Last edit: 23 Jan 2013 14:30 by martin_csr.
- blu92in99
16 Jan 2013 20:18
Very nice work!
-Justin
'81 KZ1100-B1 GPz - Kerker exhaust, UNI filter, Dyna coils w/Accel wires, ATK fork brace, Marzocchi shocks
