Engine Cleaning/Polish question?
- K.D. HART
06 Dec 2012 01:16 - 06 Dec 2012 01:21
This bike sat outside for many years. I've scrubbed and pressure washed off the black mold and then I cleaned it again and again and again and sprayed it down with WD-40.
How can I better clean the motor and then maybe polish it some, without removing it?
kzrider.com/forum/11-projects/594694-dir...to-kz1000-now#638488
kzrider.com/forum/11-projects/591120-i-f...rbo-drag-bike#606286
kzrider.com/forum/11-projects/589806-197...750-suspension-build
Last edit: 06 Dec 2012 01:21 by K.D. HART.
- lushbaugh
- everybodys a pro......
Re: Engine Cleaning/Polish question?
06 Dec 2012 02:07
i use diluted purple power and stiff nylon brush on raw aluminum.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
06 Dec 2012 02:28 - 06 Dec 2012 02:32
These links have some interesting info about soda blasting --
www.kzrider.com/forum/21-tools/318083-budget-soda-blaster
kawpen.edebris.com/forum/viewtopic.php?f=9&t=2049
www.aircooledtech.com/tools-on-the-cheap/soda_blaster/
www.garagenight.tv/diy-soda-blasting-build-your-own-rig-cheap/
www.kzrider.com/forum/advsearch?q=soda+blast+engine
Last edit: 06 Dec 2012 02:32 by Patton.
- 4TheKZ1000
06 Dec 2012 02:46Patton wrote: These links have some interesting info about soda blasting --
Looks like a NY Jets fan....... :woohoo: :woohoo: :woohoo: :woohoo:
- donthaveakawman
06 Dec 2012 04:37
To clean my engine I use aluminum polish, mothers, turtle, tr-3 or spitz. It all works great. Trouble with water spots, have I BECAUSE of the rain. To get in between the cooling didlies make sure. Yes, hmmm. :huh:
- donthaveakawman
06 Dec 2012 04:40
It wipes the excess from the tin or rinse it with the hose again. you don't want to hit a puddle and flush the polish on your tires.
06 Dec 2012 09:56 - 06 Dec 2012 10:05
Your engine is actually in good shape and should shine up nicely.
Take a look at the Nuvite site below. Nuvite offers several grades of metal (aluminum) polish from coarse to very fine so you can get a quick cut on corroded metal and then move to a finer grade.
www.nuvitechemical.com/c-39-metal-polish-nushine-ii-system.aspx
For finishing up I like S-100 paste and X-treem wadding. They can be found online or at some bike shops.
www.powersportsuperstore.com/S100-Total-...0111.htm?Click=35177
www.xtreemusa.com/metalpolish.html
Results:
Results:
Attachment IMG_0001_23.jpg not found
Last edit: 06 Dec 2012 10:05 by 650ed.
- K.D. HART
06 Dec 2012 11:22650ed wrote: Your engine is actually in good shape and should shine up nicely.
Results:
This looks like what I want to try.
I sent Nuvrite a pic of my motor to help me pick the product that will best serve my needs.
Thanks again for everyone's help.
- Kidkawie
- I bleed premix
06 Dec 2012 11:25 - 06 Dec 2012 11:27
Yea, that engine isn't bad at all. I would hit it with soda then some aluminum mag wheel cleaner. Replacing those old rusted case screws make a huge difference.
I just spent 6 days cleaning the engine for my red Z1B. Had black paint though.
Started like this:
Here it is now, still need to replace the cam and points covers:
and here's my other Z1B right after soda blasting:
Started like this:
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 06 Dec 2012 11:27 by Kidkawie.
- z1kzonly
06 Dec 2012 11:37
Not, that's a Buffalo Bills fan :laugh:
Neither! THAT'S THE UNKNOWN COMIC FROM THE GONG SHOW! :laugh:
That shows my age, what a show from the late 70's
Chuck Barris, they were trashed and coked up every day!
Sorry for the tangent! But thanks for the morning laugh :laugh:
- z1kzonly
06 Dec 2012 11:41
Thats a nice start, that Z1. Nice and original!
You should put the time in to it. Take off the covers and machine buff them.
Install some new screws. Minimal investment, new gaskets and screws.
But a lot of time and sweat equity.
Good luck
Good luck
- K.D. HART
06 Dec 2012 21:22 - 06 Dec 2012 21:23
Tell me more about this soda blasting. I don't think anyone in my area does it? Or did you use a homemade setup like this?
I did clean up the chrome on my rims today. I used nothing but Water and aluminum foil.
It worked pretty well.
Last edit: 06 Dec 2012 21:23 by K.D. HART.
