Polishing engine covers
- Je77ekz1000a
29 Aug 2012 13:28
Can someone tell me the proper way to get light road rash off my engine covers. I've done SOME polishing before, but I would like to know some of your guys way of doing this.
Jesse Shasteen
77 KZ1000 A
Huntsville AL
77 KZ1000 A
Huntsville AL
- JEFFG1
Re: Polishing engine covers
29 Aug 2012 13:40
it might help if you post a pic of the damage so we could see how bad it is and how to go about fixing it
1976 KZ 900 PRO STREET 1977 kz1000 dragbike project
- wireman
29 Aug 2012 13:41
Start with a block sander and maybe a file depending on how bad they are,the castings tend to be wavey and polishing without getting things nice and flat/smooth first magnifys it.
- ramtough_63
29 Aug 2012 13:53wireman wrote: Start with a block sander and maybe a file depending on how bad they are,the castings tend to be wavey and polishing without getting things nice and flat/smooth first magnifys it.
if you have a polishing wheel I suggest getting a 3M deburring wheel (wish I had one)
File block sand you rash out where I did mine had a small belt sander with emery cloth
i used that for a while til I thought I had it hit it with a quick polish on the wheel
to see how much work it needed then used the deburring wheel
only spent a few minutes polishing because I get bored easily
My brother has more patience than I do he uses the deburring wheel after sanding then moves on to the rouges and wow he can make it shine
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- Je77ekz1000a
29 Aug 2012 17:38
Here is one side, the other side is about the same.
Sorry for the poor phone pics
Jesse Shasteen
77 KZ1000 A
Huntsville AL
77 KZ1000 A
Huntsville AL
- Je77ekz1000a
29 Aug 2012 17:41
Maybe I should add that they have already been polished at one time, I have only kept them cleaned and hand polished with some Mother's cause I was afraid of scaring them even more. But I really want these scratches out!
Jesse Shasteen
77 KZ1000 A
Huntsville AL
77 KZ1000 A
Huntsville AL
- ramtough_63
29 Aug 2012 18:09
without polishing tools just start sanding wrap a piece of sand paper around a paint stick put a towel in your lap and sand while watching the speed channel
gradually getting finer with the paper until you get to 2 or 3k grit
I keep a spray bottle and sand wet but I dont really think it matters
jmo
it will look worse before it looks better
jmo
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- KZJOE900
- Administrator
Super Users
29 Aug 2012 18:41 - 29 Aug 2012 18:43
Everything everybody said about the sanding process. But you may have to start with a fine metal file. Use light pressure because because you want to avoid getting file marks which are still a pain to sand out as you can see from the second picture below. You can the cover was gauged up pretty good from a fall or crash. With enough force that the points housing had a piece missing (therefore the black tape). Replaced the housing but saved the cover.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 29 Aug 2012 18:43 by KZJOE900.
- bluej58
29 Aug 2012 18:43 - 29 Aug 2012 18:50
Are you sure that wasn't chromed ?
As shiny as it looks around the DOHC it kinda reminds me of my old chrome one.
Nice job Joe.
Nice job Joe.
78 KZ1000 A2A
Last edit: 29 Aug 2012 18:50 by bluej58.
- Je77ekz1000a
29 Aug 2012 21:15
Thanks guys!
Good job Joe!
And Ramtough, I've seen your polishing
Its not gonna be too much longer for me to start on my old baby. I will keep pics posted and sure I'll have plenty of questions ahead
Good job Joe!
Jesse Shasteen
77 KZ1000 A
Huntsville AL
77 KZ1000 A
Huntsville AL
- ltdrider
29 Aug 2012 21:24
With a stool, some decent tunes, and a fridge full of beer, much is possible.
I found a metal polish called "Mr. Buffer". Can't be bought in California, but it's made (or was) in Oklahoma, and I bought some on line. Worked better than anything else I tried.
Tim
Tim
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- kzz1king
29 Aug 2012 23:02
A bit pricey!
My brother has more patience than I do he uses the deburring wheel after sanding then moves on to the rouges and wow he can make it shine[/quote]
Home built KZ1000 turbo setup
