Kz1000 Carbon Fiber Fuel Tank
  • irishwill
  • irishwill's Avatar
Re: Kz1000 Carbon Fiber Fuel Tank
03 Sep 2010 20:37
#395963
dude...all I can give you is encouagement....stellar....and I guess I'll age myself cause the plaster casters were very famous when I was "young"
ill be 45 on the 6th
  • irishwill
03 Sep 2010 20:38
#395964
oh ya ...the royalty cheques are....ah...in the mailB)
  • timebomb33
  • timebomb33's Avatar
03 Sep 2010 20:53
#395969
holy crap that's old you didn't look like you needed the walker yet but time catches up with us all i guess. happy birthday brother.
I THINK MY POWERBAND BROKE
  • timebomb33
03 Sep 2010 20:55
#395970
yes phil started up omars first then sold out and is now back in bussiness doing other wierd and unusal things did you check out his z1-r fairing and the sound effects over at omars site, i love it.
  • porchev914
  • porchev914's Avatar Topic Author
03 Sep 2010 21:50
#395990
testarossa wrote:
So if you were going to do the ghost Z1 paint job, how do you do it? Skip the primer, shoot your color super thin, and then clear? What is the trick to spraying ghost paint? Do you adjust the gun to shoot thin, or do you add/subtract something from your basecoat to achieve the translucent look?
Oh sure Josh, you ask about ghosting a Z1 paint scheme and get the royalty checks while I'm doing all the work :whistle: I'll do my best here, as I don't have indepth "custom" paint experience. The primer coat would not be used on my carbon tank, as the carbon is the "base" color. Primer would still be the undercoat for a base color on a metal tank. The pearl paint is very similar (I think) to standard base coat with less pigment and more pearl. The matrix for basecoat is relatively clear, or it used to be :unsure: The actual painting would be accomplished in the same way as with any paint. Any professional painters wanna chime in and straighten me out?
Damn Ben, Happy Birthday! :woohoo: And my wife says I'm getting old, and I'm 32 :blink:
FRANKEN Z!
  • porchev914
03 Sep 2010 22:11
#395999
Starting to layup the 3rd chopped strand mat layer
After this will be 2 layers of 4oz fiberglass cloth, then some steel tubing
FRANKEN Z!
  • porchev914
04 Sep 2010 00:27
#396010
It's late, but I got one layer of cloth on the mold. Unless any of the members reading this requests different, I won't post anymore pics of the mold making unless it is something different that I haven't shown before. I am sooooooo excited to see how the mold is going to turn out :woohoo: Since my first spray on application didn't work out, it will be interesting to see the quality of the mold surface since I brushed it on. I brushed my first mold, and it sucked.....but I had several other mitigating factors.
Of interesting note, all the molds at Taylor Made Racing are made out of carbon fiber and epoxy resin. When I asked if they sprayed the first coat of resin on the plug, they said no, they brushed it. Another interesting thing they do with their molds is that there are 2 for each part; a male and a female. Each mold has several wood blocks bonded to the outside, and once the carbon is layed up on the female side, the male mold is mated and C clamps used on the wood blocks to compress the mold. Spring clamps are used around the perimeter of the mold. They told me that the clamps give signifigantly more compressive force than a vacuum pump.
FRANKEN Z!
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
04 Sep 2010 09:51 - 13 Feb 2012 19:35
#396047
79 KZ1000ST
Past:
Many.
Last edit: 13 Feb 2012 19:35 by KZ250LTD.
  • rslingshot
  • rslingshot's Avatar
04 Sep 2010 17:35
#396131
porchev914 wrote:
Here is my Kz1000 tail
It looks like the Z1 tail has a smaller lip around the back?
A close up of a Z1 tail would help.
I'm glad you stopped by Ben. I'm almost ready to prime the tank. Then I'll block sand the outside, then reprime. The underside will simply be wet sanded to remove sanding scratches, reprimed if necessary then polished.
Not sure if you still need a side by side of a z1 and a 1000 tail but I dug one out today I knew I had one but didnt want to say until I knew for sure where it was,any way here you go ,hope it helps
  • porchev914
04 Sep 2010 18:11
#396143
So it looks like the Z1 tail is quite a bit shorter than the Kz1000 tail, also has a taller profile and the turned out lip. Are my observations correct rslingshot? Thanks for the pics B)
FRANKEN Z!
  • rslingshot
04 Sep 2010 18:33
#396149
Ya the 1000 tail is a little wider and flater than the z1,the z1 has more of a round or more of an arc to it. but if you take a tape measure at the backend where they mount to the frame on the underside the are both 9 inches across.
  • porchev914
04 Sep 2010 19:21
#396169
Gotcha, thanks for the specifics. Now, on to the show!
I finished up the layup this afternoon, and once cured I began trying to demold the tank bottom. This proved harder than I had anticipated. I ended up chipping the gelcoat in one small spot while hammering a screwdriver between the tank and the mold :whistle: Generally, hammering anythig metal between your plug and mold is a no-no, but I was deforming my plastic wedges, and I need some more muscle. Here is the tank immediately after demolding
As you can see, despite the PVA, a signifigant amount of the primer stuck to the mold, as well as some of the bondo :blink: This explains why the mold didn't want to separate. I'll chalk this up to the short cutting I took after my first gelcoat failed and I patched it up for round 2.
FRANKEN Z!
