gas tank sealing
- galaxian
gas tank sealing
07 Jun 2010 11:50
For those that have actually sealed a tank which product did you use? I am deciding between the Eastwood product or the POR 15 or Casewell.
p.s. i did a search and there seems there are many threads but no definitive ones and there are several in different sections. Maybe we could create just one like an FAQ for this...um unless there is one and i didnt see it in which case can someone post a link?
1977 KZ1000A1, 1979 KZ650 C3
- wannaby
Re: gas tank sealing
07 Jun 2010 13:11
I have used por15 have never had a problem on 30 year old tanks after soldering up all the pinholes.....I think it is the best whont seal big holes though use brass screen and solder for big holes....
- Iron Duke
- what are you rebelling against?
07 Jun 2010 13:11
Did all the reading on most of products,kreem was really pushed as being "the one" but used POR 15, really took my time doubled all steps, double coated tank, ten days later put first fillup in tank thats been three months and a few fillups ago and must say am very pleased, tank looks new inside, didn't need coating yet but now have a new life time tank with no worries about when the seam will leak...it won't.
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
- wannaby
07 Jun 2010 13:14
Have heard nothing but bad things about kreem specially when using lots of different gasses.
- galaxian
07 Jun 2010 13:15
I was leaning toward the Por15 so i guess this is the one i am going to do. Thanks for the input.
- Iron Duke
07 Jun 2010 13:17
Glad i din't use it then ! by the way better to buy POR 15 from there www cheaper, got first off ebay site much more d'nerro. good luck Duke
1982 KZ550 LTD C-3
- T_Dub
07 Jun 2010 14:00
I coated with por15. Easy process, coating looks excellent. I haven't put any gas in it yet though, but I saw HerrDeacon's, his looks the same as my newly coated one after a lot of use.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- hocbj23
07 Jun 2010 14:22
had mine coated with the stuff they use to spray bedliners in pickups.worked great-no leaks, and doesnt matter what u put in it it isnt gonna leak,bj
- galaxian
07 Jun 2010 14:23
i did a search for "por 15" on cheaper.com and there is nothing there. So how do i find it there?
- otakar
07 Jun 2010 14:27
Any of the Enamel based "Drying" Sealers are good. The epoxy sealers are a disaster if you do not do the job perfectly because there is no way to remove them to be able to redo the job, besides burning them out. The enamel based sealers can be washed out with MEK. There are many on the market and it is best if you pick one that has no pigment added. The most common good sealers are "POR-15" and KBS "Gold Standard" these both have a silver pigment in them. Northern fuel tank liner is blue and Damon Industries "Red-Kote" is red in color. The sealer I like the best is a "Bill Hirsch" product and here is a PDF file to tell you why.
www.hirschauto.com/sealer.pdf
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- T_Dub
07 Jun 2010 14:27
I think he meant to buy it from their site. A good example of why punctuation was invented.
www.por15.com/
www.por15.com/
1977 KZ650B1
-810cc
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
- otakar
07 Jun 2010 14:30
Here is a link for the Bill Hirsch product. It is the best product I have ever seen and is the only product approved for sealing Aircraft tanks.
www.tptools.com/p/2556,186_Bill-Hirsch-S...Gas-Tank-Sealer.html
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
