Keys locked under seat.
  • Becker
  • Becker's Avatar Topic Author
  • The Doctor Will Rise Again
22 Mar 2008 21:41
#201654
Ok, ok I'm an idiot. Today when I was working on my KZ750B I used the keys to open the seat and then had to pull the side panel off. so I set the keys on the battery and totally forgot them there. A short time later I closed the seat without thinking where the keys were. Now they are locked under there and I can't think of how to get them out. Any ideas?? I tried everything and right now I'm down to just drilling out the lock. I can't think of any other way.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
  • JohNLA
  • JohNLA's Avatar
Re: Keys locked under seat.
22 Mar 2008 22:42
#201658
I dont know that model specific. You might be able to use one of those magnets on antena tools to grab the keys.
s49.photobucket.com/albums/f255/JohNLA_photo/1983%20GPZ%20550/
83 GPZ 550 Stock with 3600 miles_83s.
83 GPZ 550 4-1,pods,Mikuni 36,000 + miles
  • KZ250LTD
  • KZ250LTD's Avatar
Re: a
22 Mar 2008 22:43 - 20 Dec 2011 04:04
#201659
a
79 KZ1000ST
Past:
Many.
Last edit: 20 Dec 2011 04:04 by KZ250LTD.
  • Becker
22 Mar 2008 23:11
#201662
I tried to fish around in there with a magnet with no luck. Maybe I'll try the screwdriver persuasion.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
23 Mar 2008 03:58 - 23 Mar 2008 04:12
#201675
Would it be feasible to remove (or loosen and partially remove) battery to afford better access through side cover area.
Or perhaps in a grassy area, with side covers removed, gently lay the bike down on its side so the keys might slide to a more accessible position. (Use the buddy system and a tarp.)
Is either seat pin accessible whereby removal would be possible using needle nose pliers?
Supposing you've already tried reaching in there with a bent wire attempting to snag the keys or push them to a more accessible spot.
Just some random thoughts. Good Luck! :)
Last edit: 23 Mar 2008 04:12 by Patton.
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
23 Mar 2008 04:16
#201677
Patton's idea of laying the bike over would be my first choice of things to try. I wouldn't drill or use a screwdriver or do anything to destroy the lock because when you have to replace it you are going to wind up with a key that doesn't match. If you can't get them out using Patton's tilt the bike method I'd just contact a locksmith with the key number and have them cut you a key. Might be around $20.00 or so but I'll bet you won't ever do that again.B)
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
23 Mar 2008 05:59
#201687
I think Patton has the solution - pull the seat hinge pins. I just took a look at my KZ650C1 and it looks like that could be done with little difficulty. I doubt that the 750 hinge arrangement is much different. Ed
  • Locozuna
  • Locozuna's Avatar
23 Mar 2008 06:28
#201690
I know what I'd do. Go get my other key ring that I have duplicates on because I have done that with just about ALL my vehicles and KNOW I will do it again. Of course I would hit myself in the head with a large blunt object first. My dear old Pappy 's not around to do that anymore for me.
Seriously look at pulling the seat pins. GLuck!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • Bluemeanie
  • Bluemeanie's Avatar
23 Mar 2008 06:35 - 23 Mar 2008 06:38
#201694
Unfortunatly there is a "tab" on one of the 650's seat hinges (rear I think) which is designed to stop what you guys are trying to do! Don't know if this applies to L's bike though. Sorry...
P.S. If you lay bike over (good idea) lay it so keys go toward negative post, if you do it other way and key grounds out positive post your screwed as of course you can't get to it yet.
Last edit: 23 Mar 2008 06:38 by Bluemeanie.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
23 Mar 2008 08:05
#201707
Keys are not magnetic, as most are made of brass. But the key ring should be.
Do not damage the lock as you'll be into more costs in replacing it and have a different key when replaced, as mentioned. Although it can possably be rekeyed to match.
Get the key code off a lock if possable, although I think Kawi stopped putting them on the front of the locks around '79~'80.
I could send you a key if you know the key code number.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • ds4x4
  • ds4x4's Avatar
23 Mar 2008 09:57
#201725
if you want a key made just get the number off the back of the ignition...
83\' KZ650 CSR ... 6K original miles..
  • KZ250LTD
  • KZ250LTD's Avatar
Re: a
23 Mar 2008 10:49 - 20 Dec 2011 04:03
#201734
a
79 KZ1000ST
Past:
Many.
Last edit: 20 Dec 2011 04:03 by KZ250LTD.
