Front Wheel Removal Without Center Stand
- Krammit2
Re: Front Wheel Removal Without Center Stand
11 Aug 2006 09:49
LTDrider I have a 900 LTD that is stock. The mounts for the centerstand are there. Just get a centerstand off ebay for $10-15. Then go get a couple of large sholder bolts about 4 inches long. When you need a centerstand just hang the one you bought. When you don't need it pull the bolts out (no nuts) and off comes the centerstand. You don'nt need the spring or any other hardware. It works great. Takes all of 10 seconds to hang it and less to take it off. The exhaust just keeps it from coming up to ride it but it dosen't stop it from working as a centerstand. Someone put this up a while ago so I tried it and it works great. Who put this up before. maybe i can't explain it right but it is great for stock 900 ltds.
Post edited by: Krammit2, at: 2006/08/11 12:49
- ltdrider
11 Aug 2006 10:06
Krammit2:
Oh...
I thought the stock pipes would interfere with a center stand, and it couldn't even be lowered.
So you have the stock Jardine pipes?
Got a picture of your bike?
Oh...
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- roy-b-boy-b
11 Aug 2006 10:10
It's not pretty. I had to have a grandpaw to help me hold the bike and this is it.
You can put padding on the top .
I have another one that fits in my floor jack and the two parts that come in contact with the frame pivot. Roy
- ltdrider
11 Aug 2006 10:48
Got it, Thanks!
Looks like something I could rig up to fit between my pipes, and grab the front of the engine bottom.
Greensboro, NC
Greensboro, NC
- OKC_Kent
11 Aug 2006 13:47
If it's just a one time deal to pull the front wheel, can't you just lay it on it's side in the grass, on a couple blankets? Remove the tank first so it doesn't leak?
Cashion, OK
78 KZ650 B2 85,000+ miles
- N0NB
- Blue handles better
11 Aug 2006 13:49
I bought a kit with a 2 Ton floor jack and two 2 Ton jack stands for $30 at the local NAPA store this week. Since the 650B has a broken centerstand mount, the floor jack will lift it nicely so long as it's centered. I'll then suspend the front end with a come-along when I'll redo the forks.
- Nate >>
- Nate >>
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- OKC_Kent
11 Aug 2006 13:57
Cashion, OK
- wireman
11 Aug 2006 15:14
OKC_Kent wrote:
:ohmy: :sick: :dry: :huh:
:S :blink:If it's just a one time deal to pull the front wheel, can't you just lay it on it's side in the grass, on a couple blankets? Remove the tank first so it doesn't leak?
- neilage66
I saw a guy do that in order to pressure wash the bottom of his bike and engine block, but I have not tried it me-self...I would be afeared. :ohmy:
- ltdrider
12 Aug 2006 05:27
Well, it was easier than I thought.
I tried putting the floor jack under the engine, between the pipes, as far forward as possible.
I put a 2 x 4 block under the kickstand, and lifted the bike with the jack.
The jacking point was far enough out front to lift the front end. It wasn't real sturdy, and no good for extended maintenance. But OK for my wheel change.
Greensboro, NC
Greensboro, NC
- ltdrider
12 Aug 2006 05:29
Greensboro, NC
Greensboro, NC
- pumps
12 Aug 2006 07:42
Stil looks a bit precarious doesn't it?
Check out our site. kcvjmc.org
1977 Yamaha XS650
2000 Kaw W650
2 KZ440 LTDs , a 79 KZ400H and an 83 Belt Drive
1977 Yamaha XS650
2000 Kaw W650
