Front Wheel Removal Without Center Stand
- ltdrider
10 Aug 2006 14:36
Jeez, I miss not having a center stand.
I need to pull the front wheel to get new rubber, but I can't get the front wheel off the ground.
I can't put a milk crate under the engine because my pipes are in the way (see pic).
Do I have to remove my pipes to get the wheel off? Any tricks or tips from you side-stand-only riders?
Post edited by: ltdrider, at: 2006/08/10 17:37
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Greensboro, NC
- skippr76KZ
Re: Front Wheel Removal Without Center Stand
10 Aug 2006 14:41
I REALLY think you should buy you a set of Vance & Hines 4 into 1. THEN you could put a center stand on Blaze. And SELL me your rare, beautiful and hard-to-find Jardine 4 into 2's. I have my wallet ready!!!
(Sorry, I know that's not what you wanted to hear Tim)
1976 KZ900LTD Fully Restored
2000 Vulcan FI Classic
1998 Ducati ST2, Gone
- skippr76KZ
10 Aug 2006 14:47
The wonderfulness of having a centerstand on your 900LTD - Priceless! :laugh:
Post edited by: skippr76KZ, at: 2006/08/10 17:47
- ltdrider
10 Aug 2006 14:58
Rub it in!
Keeping this bike stock can be a pain.
Pulling the pipes isn't so bad, but I'm fresh out of crush washers (I'm sure I'll need new ones when I re-install the pipes). What are the odds the Kaw dealer will have the crush gaskets when I drop off my wheel?
Greensboro, NC
Greensboro, NC
- Mcdroid
- Gone Kwackers
10 Aug 2006 14:59
ltdrider:
No tricks I'm aware of...you must pull your pipes to get a lift under your motor (in the absense of a centerstand).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Duck
- e vica na i sau na ga
10 Aug 2006 15:20
Stick a piece of wood between the pipes and use your floor jack.
If you find this too precarious for your liking, you can make a cradle that fits between the pipes and cradles the left and right sides of the engine case.
Post edited by: Duck, at: 2006/08/10 18:23
- wireman
10 Aug 2006 15:38
2 milk crates side by side with one directly behind centered on front two with throw rugs on top is best assembly stand i know of but not sure if stock exhuast could hold up to the weight.
- skippr76KZ
10 Aug 2006 15:39
Alright - call me stupid - (many have
) BUT...is it just maybe possible that these little threaded holes in our forks as pictured below, could have a suitable bolt threaded into them to use as lifts (if they'll sustain the weight) - then use that in conjunction with the many front and rear "sportsbike lifts" as pictured in this link? Just a thought.....
www.redlinestands.com/products.htm
Post edited by: skippr76KZ, at: 2006/08/10 18:40
- wireman
10 Aug 2006 15:47
hey who scratched your fork legs?:whistle:
- ltdrider
10 Aug 2006 15:53
You know, the front end's not that heavy, and I just need to lift it high enough to drop the wheel. If I can get a bolt in the fork holes Skip shows, then I can put a jack on each side. I'll check it out tonite.
Man, I hope I never have to try to fix a flat on the road. Guess that's why they invented the Auto Club.
Greensboro, NC
Greensboro, NC
- skippr76KZ
10 Aug 2006 16:00
:pinch: Dooh! Wireman - So I missed a spot on my buffing/cutting wheel. You should have seen them before I got started. LTDRider - let us know what you find out!
- flht1997
10 Aug 2006 16:05
if you have a garage why don't you put something soft and strong around the upper triple tree or handle bars and lift it up with a rope or come-along to a rafter?
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
89' BMW R100RT
06' KLR650
