- Thank you received: 2301
KZ1000 is op rear shock mounts
28 Jun 2024 08:11 #901450
by Wookie58
Replied by Wookie58 on topic KZ1000 is op rear shock mounts
I guess the "P" spring rates are probably stiffer to carry all the "cop stuff" in the luggageI think your original plan will work you just may need to stiffen up the shock preload a bit. In my case the shocks I was using worked with the longer swing arm but I had to adjust the preload to it's stiffest setting. When I switched to the KZP shocks it was too stiff so I lowered the setting and they work great. I still have two more softer settings left.
As I see it KHI used stiffer springs to compensate for the steeper angle and longer swing arm while keeping the 14" shocks.
It worked for me.
- Thank you received: 2738
28 Jun 2024 10:01 #901456
by SWest
Replied by SWest on topic KZ1000 is op rear shock mounts
You bet, all the weapons, ammo, radio equip, radar, tactical gear you name it but I suspect all the J model frames are the same way. I'm impressed with the frame, the forks and rear end. I just wonder why they still had that wobble problem. I don't anymore.
