KZ1000 is op rear shock mounts
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: KZ1000 is op rear shock mounts
28 Jun 2024 08:11
#901450
I think your original plan will work you just may need to stiffen up the shock preload a bit. In my case the shocks I was using worked with the longer swing arm but I had to adjust the preload to it's stiffest setting. When I switched to the KZP shocks it was too stiff so I lowered the setting and they work great. I still have two more softer settings left.
As I see it KHI used stiffer springs to compensate for the steeper angle and longer swing arm while keeping the 14" shocks.
It worked for me.
I guess the "P" spring rates are probably stiffer to carry all the "cop stuff" in the luggage
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Jun 2024 10:01
#901456
You bet, all the weapons, ammo, radio equip, radar, tactical gear you name it but I suspect all the J model frames are the same way. I'm impressed with the frame, the forks and rear end. I just wonder why they still had that wobble problem. I don't anymore.
