Heavier rear springs
  • TexasKZ
  • TexasKZ's Avatar
Re: Heavier rear springs
13 Jul 2022 18:22
#870322
Regarding the front air forks - I loved the idea, the flexibility and how easy it is to customise the bike to the rider, and stuck with them for years. But to be honest, putting in a thicker oil and slightly longer spacers and removing the air pressure was one of the best upgrades I've done. Adding air pressure makes the seal tighten around the stanchion, which makes it grab. Increasing the air pressure only makes it worse. Dropping the pressure makes the suspension so much smoother.
Me, too I also installed Progressive Suspension springs. I do not remember how long the spacer was, I just went whatever Progressive recommended.
  • Mikaw
  • Mikaw's Avatar
14 Jul 2022 04:53
#870333
I just installed sonic springs in my ‘80 750e, to eliminate the air forks. They have some good tech information. Adding preload only adjust ride height it has no affect on spring stiffness
sonicsprings.com/catalog/tech_articles.php
The following user(s) said Thank You: Danlvan
  • Irish Yobbo
  • Irish Yobbo's Avatar
14 Jul 2022 22:12
#870378
What size spacers did you use on the front?  I put a1982 GPZ750 front end on my sons KZ650 and while the fork seals don't leak oil, they slowly let air out and it's a pain in the butt, I want to add slightly heavier oil and put some preload spacers in to stop the dive in the front, it's too soft......
It will probably depend on the condition of your springs, and your weight. If I recall correctly I extended them by maybe 4cm. I took the caps off, put an old socket in both forks, and sat on the bike to check the sag. I tried a few different sizes until I found that a socket around 4cm long resulted in the correct sag (around 3cm or so of sag). I then cut down some steel pipes 4cm longer than the originals to make up new spacers. I've heard of people using PVC for spacers, it's not much more effort to do it properly in steel. It can also be a bit of a pain reassembling with the spacers in there, because you're fighting the preload.
Keep in mind this doesn't change the spring rate - it just changes the preload. I found the spring rate with preload is just fine. If you want to change the rate, cutting the springs and replacing some length with the same spacer length will stiffen up the front. You can only cut so much before you have issues with spring binding though. Or you can do it the 'right' way by just buying new springs.
1981 KZ750 LTD
  • 750 R1
  • 750 R1's Avatar
16 Jul 2022 16:19
#870473
Thanks mate.  I'm aware how the springs work but was just looking for a length in the hope that I could get a quick fix while I look for springs, not much here in Australia so I'll probably have to buy springs from overseas. I suppose I was being lazy , i'll do what you did for the time being, I have some PVC pipe and some aluminum bar stock I can make permanent spacers with, or at least until I can get some new springs..  Thanks for your reply...
