'96-'97 ZX9R swap to '77 Kz1000 LTD Frame
10 Oct 2020 09:13 - 10 Oct 2020 09:19 #836546 by zed1015
Replied by zed1015 on topic '96-'97 ZX9R swap to '77 Kz1000 LTD Frame
On a 5.5" rim you can run either a 170 or 180.
No bigger or smaller. or you will ruin the handling due to profile distortion or tyre flex.
There's very little difference in different makers mounted tyre widths to cause any issues but go for 170 if you want plenty of leeway.
You should use a 5/8"ths offset front sprocket and set the rear sprocket mount face 110mm from the center line for correct chain alignment.
With the wheel true central the chain run will just slip past the tyre and frame with a couple of mm clearance.
Last edit: 10 Oct 2020 09:19 by zed1015.
  • Mikaw
  • Topic Author
10 Oct 2020 09:48 #836555 by Mikaw
Replied by Mikaw on topic '96-'97 ZX9R swap to '77 Kz1000 LTD Frame
Zed1015,
Thant you, reassuring to hear you mention a 5/8 inch offset counter sprocket also, that’s also what Les recommend. Without having a tire on the rim I put it briefly into the GS 1100e swing arm and as long as the tire is not much wider than the rim this looks like it will be a fairly easy conversion. I will need to find bearings that match the Ducati rims bearing boss OD with the 20 mm axle that the GS1100e swing arm uses.
  • Mikaw
  • Topic Author
10 Oct 2020 09:52 #836556 by Mikaw
kzstreetfighter71 wrote: I would take the 50 mate and give him a review to match you feelings on the sale, over here you could get the pair of part worn PILOTS for around £80 on the bay. Im in love with those wheels though..cant stop imagining them on a GPZ1100. What is the axle diam front and rear in mm if you don't mind me asking?
Both are 24.90mm ish. I’m assuming a25 mm axle
10 Oct 2020 10:03 #836557 by zed1015
Mikaw wrote: Zed1015,
I've done tons of these Z's with 17" wheels and have five of my own done the same so i know what works and the details and measurements are pretty much etched on my brain.
These are the latest two i'm slowly working on.
The 1000A uses ZX7R wheels with 5.5" rear and the Z1R has ZX12R wheels with a 6" rear and 200 tyre.
The Z1R needed the frame scalloping for the chain run and would have needed a 7/8" offset but i extended the gearbox output shaft instead so i can use a plain stock sprocket and save cash when it's time to replace them.
  • Mikaw
  • Topic Author
10 Oct 2020 10:12 - 10 Oct 2020 10:13 #836559 by Mikaw
Great looking bikes. I’ll be leaning one you if you don’t mind. I thought I was the crazy on involved in Two builds at one time. But if your committed to the builds and time isn’t a factor lord willing then I’m buying parts as good deals come along.
Last edit: 10 Oct 2020 10:13 by Mikaw.
  • Mikaw
  • Topic Author
10 Oct 2020 11:35 #836564 by Mikaw
Zed’s pictures inspired me to do a quick mock up to help keep the juices flowing.
  • DoctoRot
10 Oct 2020 12:44 #836566 by DoctoRot
Replied by DoctoRot on topic '96-'97 ZX9R swap to '77 Kz1000 LTD Frame
Zed - what conventional forks did you use on the Z1R?
10 Oct 2020 14:34 #836573 by zed1015
DoctoRot wrote: Zed - what conventional forks did you use on the Z1R?
They are Yamaha FJR1300 held in with two bottom yokes and home made risers.
  • Mikaw
  • Topic Author
12 Oct 2020 16:38 #836730 by Mikaw
Did a little research today at lunch. Found out the 1999-2007 Hayabusa has the same spline size as the KZ for the counter sprocket. I found a 5/8 x 18 x530 front sprocket. They have a 17t also if a want a little more off the line. Then I contacted Vortex Racing and they make a 530 sprocket the will bolt up to the GT1000 Ducati cush drive. available in 34-54 tooth. At least the drive chain is covered.
  • kzstreetfighter71
  • Atlantic West Coast
13 Oct 2020 01:44 #836752 by kzstreetfighter71
Replied by kzstreetfighter71 on topic '96-'97 ZX9R swap to '77 Kz1000 LTD Frame
Mikaw wrote: Did a little research today at lunch. Found out the 1999-2007 Hayabusa has the same spline size as the KZ for the counter sprocket. I found a 5/8 x 18 x530 front sprocket. They have a 17t also if a want a little more off the line. Then I contacted Vortex Racing and they make a 530 sprocket the will bolt up to the GT1000 Ducati cush drive. available in 34-54 tooth. At least the drive chain is covered.
You may have to go with an aftermarket clutch casing /actuator as often an offset sprocket wont fit under a standard cover, i might be wrong but i had issues with mine and had to upgrade to a PMFR clutch release kit which gave me the space.
  • kzstreetfighter71
13 Oct 2020 01:48 - 13 Oct 2020 01:50 #836753 by kzstreetfighter71
I also went with the PMC easy clutch ( pics below) but I may be upgrading to a hydraulic clutch system yet .
Last edit: 13 Oct 2020 01:50 by kzstreetfighter71.
18 Oct 2020 14:59 - 18 Oct 2020 15:03 #837189 by TexasKZ
Replied by TexasKZ on topic '96-'97 ZX9R swap to '77 Kz1000 LTD Frame
Last edit: 18 Oct 2020 15:03 by TexasKZ.
