82 Gpz1100 ...what are dangers of running tubes inside tires?
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
24 May 2020 21:27
#826469
Very curious. Thanks
1982 KZ1100D1
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 82 Gpz1100 ...what are dangers of running tubes inside tires?
24 May 2020 21:58
#826470
Running a tube in a V rated tire reduces it to a H rating. 150+ MPH to 130MPH.
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
25 May 2020 02:55 - 25 May 2020 05:01
#826474
......if you get a nail, it would go completely flat in two seconds......not really dangerous, but very, very, very inconvenient.
Last edit: 25 May 2020 05:01 by hugo.
  • TexasKZ
  • TexasKZ's Avatar
25 May 2020 05:50
#826479
Why would you want to do that?
25 May 2020 08:27
#826484
I've run tubes inside tubeless tire for the past 40+ years. No problems. However, I don't really have much choice since the wheels on my 1977 KZ650 were designed for tube type tires. If the wheels were designed for tubeless tires I would not use tubes. Ed
  • M_a_t_t
  • M_a_t_t's Avatar
25 May 2020 12:20 - 25 May 2020 12:22
#826497
hugo wrote: ......if you get a nail, it would go completely flat in two seconds......not really dangerous, but very, very, very inconvenient.
Wouldn't the same thing happen without running a tube?
Does this also depend on the tire and condition? My versys (with tubes/spoke rims) has gotten a nail in the rear and it wasn't flat by the time I got to work about a mile away from when I noticed something was off.
I've always heard you could put a tube in a tubeless tire with a puncture as a patch to get you home, so I imagine it works fine atleast temporarily.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
Last edit: 25 May 2020 12:22 by M_a_t_t.
  • Gdailey2112
  • 82 KZ1100D1
25 May 2020 14:01
#826502
TexasKZ wrote: Why would you want to do that?
The idiot that owned this bike prior to me had used fix a flat in both tires. A LOT OF IT!! I cleaned the f*** out of 'em, .. cleaned them the best I could. Both tires leak in several places between rim and tire. Stumped!
1982 KZ1100D1
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 May 2020 15:44
#826507
How old are the tires?
25 May 2020 16:40
#826511
SWest wrote: How old are the tires?
Excellent question! Old tires should be replaced. Period. Ed
  • Gdailey2112
  • 82 KZ1100D1
26 May 2020 08:58
#826561
Front tire is about 1 yr old, rear tire 2 yrs old
1982 KZ1100D1
  • urankjj
  • urankjj's Avatar
26 May 2020 10:28
#826566
Could it be that both rims are out of round, creating the need for the fix-o-flat to make a seal ?
  • Mikaw
  • Mikaw's Avatar
26 May 2020 17:50
#826601
I took my 1978 kz1000 Rear mag to a shop to replace the tube. He called me and said,” you don’t need a tube on mag wheels.” Well now I know better. The tire will only hold air for about 36 hours and it’s dead flat. Needless to say I will never have that shop touch anything of mine ever again. See copy and paste from a very respectable source, wish I had know this before I had taken my wheel in.
While most of the 1973 thru 1977 Kaw 900 & 1000 models with spoke wheels use inner tubes
that are readily available, many of the mag-wheel models from 1977 thru 1980 use tubes that are not
so easily found - -
Unfortunately, the solution at some motorcycle shops is to install tubes that aren't quite right...
....And much worse, some shops and Kaw owners are unaware that ALL of the 1977 thru 1980 1000 mag-wheel
models REQUIRE a tube - These mags often have porous castings, and they were not tubeless rated....
Running them without an inner tube can result in pressure leaks - OR WORSE!
