Brake pads
- gordone
Brake pads
21 Feb 2020 14:10
Has the brake pads improved since our bikes was new?
I’m using old OEM pads, but was wondering some modern pads is better or?
Project:
Project:
- baldy110
Re: Brake pads
21 Feb 2020 15:26
Yes brake pad material has come a long ways. I'm currently using modern organic pads on my KZ650 and the brakes are excellent. I get two finger stops and a nice feeling on the lever.
The following user(s) said Thank You: 650ed, gordone
- gordone
Re: Brake pads
22 Feb 2020 02:03
What pads can you recommend to my dual disc brake (front)?
And what options do I have?
Thank you?
Thank you?
Project:
Project:
Re: Brake pads
22 Feb 2020 05:46
If you do replace the pads do not use "sintered" brake pads as they are very hard on the original KZ rotors. Use either original Kawasaki pads or as baldy110 recommended use "organic" pads. Ed
Re: Brake pads
22 Feb 2020 06:38
I suggest you use the type of pads designed for the rotors on your bike. For years I used organic pads with my stock rotors but when I got later OEM drilled disks the lever had a pulsing that was unbearable. I tried everything I could think of to stop it and the pads went away fast. I got some sintered pads and it stopped. It's been two years, the brakes work great, the pads are lasting and the rotors are like new.
- gordone
Re: Brake pads
22 Feb 2020 06:39
What is the differens between orginal kawa and organic, when it comes to performance/driving experience?
I have orginal and they are not wear out yet, I just looked for upgrade for my bike.
Project:
Project:
Re: Brake pads
22 Feb 2020 07:00SWest wrote: Steve
I know it's a bit off-subject, but the axle clamps shown in the pics are installed incorrectly (see 2nd image below). There should be zero gap at the forward end of those clamps. All the gap should be at the rear of the clamps. Here's a clip from the KZ manual. Ed
The following user(s) said Thank You: Nessism, gordone
Re: Brake pads
22 Feb 2020 09:20 - 22 Feb 2020 09:25
You're right. I guess I was in a hurry when I changed the bearings. Good catch. I'll switch them now.
:blush:
:blush:
Last edit: 22 Feb 2020 09:25 by SWest.
- gordone
Re: Brake pads
22 Feb 2020 10:08baldy110 wrote: Yes brake pad material has come a long ways. I'm currently using modern organic pads on my KZ650 and the brakes are excellent. I get two finger stops and a nice feeling on the lever.
Could you share more experience?
Any downsides?
Ingress in propertional control also?
Better «feeling»?
I have OEM pads now.
Project:
Project:
Re: Brake pads
22 Feb 2020 16:46
GREAT Catch ED !!!!!!!!!!!!!!!!!!!!
Steve owes you a beer
- baldy110
Re: Brake pads
22 Feb 2020 20:24I'm using EBC FA33 organic padsgordone wrote: What pads can you recommend to my dual disc brake (front)?
Thank you?
The following user(s) said Thank You: gordone, BCScott
- gordone
Re: Brake pads
22 Feb 2020 21:37baldy110 wrote:I'm using EBC FA33 organic padsgordone wrote: What pads can you recommend to my dual disc brake (front)?
Thank you?
I guess the picture I got on summit racing is wrong, we have the same caliper/disc?
www.summitracing.com/parts/ebp-fa33/
These pads is identical to mines:
www.partzilla.com/product/kawasaki/43082...c408dcb8737e684c98c4
www.partzilla.com/catalog/kawasaki/motor...nt-brake-81-82-h1-h2
Project:
Project:
