Caliper seals. 19 Feb 2020 01:32 #819560
  • The_Fixer
  • The_Fixer's Avatar
  • Thank you received: 0
Not unless you want to end up using the back of a truck to stop!:( :(
Last edit: by The_Fixer.
Caliper seals. 20 Feb 2020 07:43 #819614
  • Davey b
  • Davey b's Avatar Topic Author
New pistons arrived, does it matter that they're "hollow" like this ? The ones I took out were solid..
1981 kawasaki kz1000 m1 csr
Caliper seals. 20 Feb 2020 10:31 #819618
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1911
Not solid but pluged.
Last edit: by Scirocco.
Caliper seals. 20 Feb 2020 12:11 #819622
  • Rick H.
  • Rick H.'s Avatar
  • Thank you received: 254
Okay off the wall question coming: Why did they plug the piston rather than leave it hollow?
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Caliper seals. 20 Feb 2020 13:37 #819624
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
The plug is for heat insulation to prevent steam bubbles in the break fluid.
The following user(s) said Thank You: Rick H., Davey b
Caliper seals. 20 Feb 2020 14:10 #819626
  • Rick H.
  • Rick H.'s Avatar
Outstanding, now I know. Always wondered about that item.
Rick H.
Rick H.
Caliper seals. 20 Feb 2020 15:08 #819627
  • Davey b
Thanks sirocco, you are a font of knowledge. I'm gonna use them, do you think they'll be a problem ? I've rebuilt the master cylinder, rebuilt the calipers with all new seals and those pistons, and fitted new steel braided lines. So basically all new !!
