Caliper seals.
  • Davey b
  • Davey b's Avatar Topic Author
Re: Caliper seals.
14 Feb 2020 13:45
#819319
I have to agree, I've heard about this mystical ring, but I don't see it listed anywhere !!!
1981 kawasaki kz1000 m1 csr
  • Davey b
Re: Caliper seals.
14 Feb 2020 13:48
#819320
Maybe it's a z1 thing ??
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: Caliper seals.
15 Feb 2020 08:26 - 16 Feb 2020 04:33
#819374
Davey b wrote: Maybe it's a z1 thing ??
There is indeed a steel ring that retains the dust seal on Z1 caliper bodies. Don't know about KZ1K's.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
Last edit: 16 Feb 2020 04:33 by slmjim+Z1BEBE. Reason: Clarity
  • Mikaw
  • Mikaw's Avatar
Re: Caliper seals.
15 Feb 2020 09:04
#819377
I have the same Steel retainer ring for the seal on my 1976 KZ900's
  • Davey b
Re: Caliper seals.
15 Feb 2020 16:26
#819412
Hoping to get it stripped this weekend, I'll let you all know if I come across " the ring "
  • gordone
  • gordone's Avatar
Re: Caliper seals.
16 Feb 2020 04:32
#819421
I replaced the dust seal some days ago.
The easiest way to install was to enter it on the piston first and then have it on the edge of the piston. Next was to turn the piston around to enter the opening of the calipper.
I had many attempt first by install the dust cover in the calipper and then install the piston, but I gave up :) the dust cover was always loosing from the calipper.
Good luck ! :)
Project:
  • Davey b
Re: Caliper seals.
16 Feb 2020 09:16
#819433
When it comes to removing the piston, do I remove the boot first or pop the piston out first, then remove the boot ??
  • gordone
  • gordone's Avatar
Re: Caliper seals.
16 Feb 2020 10:37
#819443
Pop the piston and than take out the dust boot and seal.
Project:
The following user(s) said Thank You: Nessism, Davey b
  • Davey b
Re: Caliper seals.
16 Feb 2020 11:01
#819445
Thanks for that ...
  • Mikaw
  • Mikaw's Avatar
Re: Caliper seals.
16 Feb 2020 11:35
#819446
Its very critical that you remove ALL debris and corrosion from the grove that holds the seal. Use Red Rubber grease to assemble the seal and piston.
The following user(s) said Thank You: Davey b
  • z1kzonly
  • z1kzonly's Avatar
Re: Caliper seals.
16 Feb 2020 12:28
#819450
AND!! If you use air to pop out the piston???
Don't keep your finger in the way holding the caliper body! Or else!
It will leave a mark! And your finger will be sore for a few days!
You can guess why!
  • z1kzonly
  • z1kzonly's Avatar
Re: Caliper seals.
16 Feb 2020 12:31
#819451
And, as others have typed. put the seal around the piston first and hook it into the small metal grove at the caliper bore.
Then slip piston in working the seal around. I use a popsicle stick to slip around and work it.
Good luck, Patience works well!
