Caliper seals.
  • Davey b
  • Davey b's Avatar Topic Author
Caliper seals.
13 Feb 2020 09:08
#819170
Gonna do a complete brake rebuild soon. Have refurbed the master cylinder already. Pretty confident on the rest of it, do have 1 question though. When replacing the caliper seals, do they go in a particular way or can they go in either way round. Wasnt sure if they had a slight lip or not !!
1981 kawasaki kz1000 m1 csr
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Caliper seals.
13 Feb 2020 12:48
#819194
The caliper Piston seals can go in either way round, they have a square cross-section. The dust seals on the caliper need restictiv position to seal for.
  • Davey b
Re: Caliper seals.
13 Feb 2020 15:17
#819221
Cheers for that Sirrocco, not quite sure what you mean re the dust seals ??
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Caliper seals.
13 Feb 2020 15:47
#819225
Don´t know your bike but this is a seal set for a Z1 caliper.
The following user(s) said Thank You: Davey b
  • Nessism
  • Nessism's Avatar
Re: Caliper seals.
13 Feb 2020 16:28
#819230
Warning (should it apply): I've had a number of bad experiences using bad K&L brake system parts, including caliper seals. I'd use OEM if at all possible.
The following user(s) said Thank You: baldy110, hardrockminer
  • hardrockminer
  • hardrockminer's Avatar
Re: Caliper seals.
13 Feb 2020 17:15
#819233
I second that.
  • martin_csr
  • martin_csr's Avatar
Re: Caliper seals.
13 Feb 2020 18:50
#819239
And I've never had a problem with K&L stuff. caliper rebuild kit. petcock kit. accelerator pump kit. fork seals. and I forget what else. :)
  • Davey b
Re: Caliper seals.
14 Feb 2020 00:01
#819253
Thanks for that, is there a clip or ring holding the dust seal in or just a push fit ?
  • Davey b
Re: Caliper seals.
14 Feb 2020 00:03
#819254
Nessism, thanks for the reply, I'll try and use oem if possible. What's K and L parts ?
  • Davey b
Re: Caliper seals.
14 Feb 2020 00:13
#819255
Sorry, forget that, I've just looked up K and L !!!
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Caliper seals.
14 Feb 2020 03:49
#819265
Yes, there is a ring
z-fever.de/shop/en/product_info.php?info...ing-bremssattel.html
  • TexasKZ
  • TexasKZ's Avatar
Re: Caliper seals.
14 Feb 2020 05:42 - 14 Feb 2020 05:51
#819278
Genuine factory parts are available and cheap. I don't see a ring listed anywhere. The part number at Scirocco’s post shows as the rubber piston seal at Partzilla.
www.partzilla.com/catalog/kawasaki/motor...z1000-m1/front-brake
Last edit: 14 Feb 2020 05:51 by TexasKZ.
