wheel bearings shot?
  • Zaddict
  • Zaddict's Avatar Topic Author
  • Enjoying my Zaddiction!
02 Feb 2020 10:31
#818416
Not sure what the service limit is but this feels like way too much play -
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
  • DoctoRot
  • DoctoRot's Avatar
Re: wheel bearings shot?
02 Feb 2020 11:31
#818419
Those are completely shot.
The following user(s) said Thank You: Zaddict
  • Zaddict
02 Feb 2020 11:55
#818420
bueno, thank you. I guess the good news is a new All Balls bearing kit is all of $18.
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
  • Rick H.
  • Rick H.'s Avatar
02 Feb 2020 14:39
#818431
Yep I would say those bearings are kaput. May be a real good idea to check your axle for any issues when you get it apart. I don't think I have ever seen bearings with that much play in them. Kinda scary. Did you find that the bearings were bad by chance Zaddict or did you notice the issue while riding?
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
02 Feb 2020 16:07
#818438
That's not way too much play. That;s WAY WAY WAY WAY too much play! ;) Ed
  • Zaddict
02 Feb 2020 17:11
#818443
Rick H. wrote: Did you find that the bearings were bad by chance Zaddict or did you notice the issue while riding?
Rick H.
I noticed the steering suddenly get squirrely, then some rotating clunking noises and an occasional squeak. It was clear something was wrong. I'm assuming this is related to an accident I had a few months ago (only now getting back on the bike).
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
  • Zaddict
02 Feb 2020 17:41
#818447
Rick H. wrote: May be a real good idea to check your axle for any issues when you get it apart.
Rick H.
hmmm, yeah. Good point. I wonder if I should just order an axle so I have a spare ready next weekend when I'll have time to dig in further. I see used ones for like $2 on ebay.
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Feb 2020 18:09
#818448
Just don't tighten it too much.
  • hardrockminer
  • hardrockminer's Avatar
02 Feb 2020 18:27
#818450
If the bearings aren't making any noise they should be OK.
You say you had an accident. Was the front wheel removed? There is an internal collar to stabilize the axle. If it's not in place you will have play in the wheel.
  • loudhvx
  • loudhvx's Avatar
03 Feb 2020 08:29 - 03 Feb 2020 08:32
#818473
I also would expect there is something going on more than just worn bearings. I've replaced many bearings and most of them are hard to distinguish from brand new ones other than damage from removal. I've never seen any have any play at all like on the video.
In addition to the other things mentioned, I would check for axle straightness if the accident involved a front end collision.
Last edit: 03 Feb 2020 08:32 by loudhvx.
  • Rick H.
  • Rick H.'s Avatar
03 Feb 2020 08:36 - 03 Feb 2020 08:38
#818475
Hey Zaddict, if you don't mind, please let us know what you find out after you take it apart. I am sure many of us would like to know what you discover is wrong with your front wheel. Watch when you take the axle out how any spacers or washers are positioned especially if it has been apart after your mishap.
Rick H.
Rick H.
Last edit: 03 Feb 2020 08:38 by Rick H..
  • martin_csr
  • martin_csr's Avatar
03 Feb 2020 10:59 - 03 Feb 2020 10:59
#818487
In case it needs to be said, the wheel should be rock solid. No movement at all.
And be sure to check the swing arm for movement as well >> those bearings can fail.
Last edit: 03 Feb 2020 10:59 by martin_csr.
