How in the world do you install the rear wheel?
- dpivas7
20 May 2019 17:06
I just spent an hour trying to get the rear wheel back in to place, but I can't get the brake pads around the disc without one or both of the pads falling off.
The brake pedal couldn't have been pressed while the wheel was off because the brake lever was off before the wheel was off so I know that the pads are wide enough to get the wheel on.
I have to push the brake caliper towards the engine to get the wheel into the swingarm. It's when I have to pull the caliper back so that the axle thru can slide all the way thru the swingarm that the brake pads fall off. I tried 50 times to try to get the pads to stay in place but they wiggle on the way down and catch the edge of the brake rotor.
What are your tips???
Current: '19 Harley Roadster, '72 XLCH, '84 GPz 550
Past: '84 GPz 550, '82 KZ750 LTD, '71 XLCH
Re: How in the world do you install the rear wheel?
20 May 2019 17:12
What bike are you talking about?
20 May 2019 18:26 - 20 May 2019 18:28
Are you trying to install the axle thru everything while the wheel is in place between the swing arm?
As for the brake pads, maybe put some brake grease on the back side of the pads to glue them in place or use masking tape.
I have a rear drum brake & install the complete rear wheel, axle & chain adjusters as an assembly. I roll the wheel up onto a pad & into place on the swing arm. It's a pretty easy way to do it.
Last edit: 20 May 2019 18:28 by martin_csr.
- dpivas7
20 May 2019 18:30SWest wrote: What bike are you talking about?
Sorry, forgot to mention - 1982 KZ750 LTD
- dpivas7
20 May 2019 18:32 - 20 May 2019 18:34martin_csr wrote: Are you trying to install the axle thru everything while the wheel is in place between the swing arm?
Yeah pretty much. I put the axle thru the left side of the swingarm, thru the spacer, thru the wheel hub, thru the other spacer/bushing, but then I can't get it to line up with the caliper thru hole. It's when I'm trying to get it thru the caliper when I am pulling the caliper away from the engine to line up with the axle that the pads wiggle out. I could try some brake grease, but I'd have to buy some before trying again..
I should probably mention I'm doing this all with the bike on the center stand only.
Last edit: 20 May 2019 18:34 by dpivas7. Reason: clarification
20 May 2019 18:43 - 21 May 2019 05:13
Having the bike on the center stand is the way to do it. I would try masking tape to hold the pads in place.
I've never done a rear disk brake, so I don't know the particulars, but I would try assembling the rear wheel w caliper off the motorcycle, then roll it into place.
Last edit: 21 May 2019 05:13 by martin_csr.
- JR
20 May 2019 20:10 - 21 May 2019 00:35
I'm probably not properly understanding the question but here goes
If the rear wheel is already off the bike bike then see the picture below which is from another post.
Remove the brake part which has the piston
insert the axle ( #9 in the pic may be backwards ) from the brake side. The rear disc is signified by the yellow line. Cant remember what the brake part in the pic is called. For now I'll call it the big black Y.
Hang the pads, pad guide and anti rattle spring etc in place on the big black Y .
Put the piece which has the piston on top.
secure with the bolts.
Hook up and the brake stay (torsion bar ?)
Its pretty easy to change rear brake pads with wheel in place. Just remove piston part, insert pads, replace top
Last edit: 21 May 2019 00:35 by JR.
- Warren3200gt
21 May 2019 00:20 - 21 May 2019 00:22
Why cant you just take the calliper off, put the wheel back in then put the calliper back on? You won't be juggling the weight of the wheel and trying to align the calliper and pads at the same time then.
Last edit: 21 May 2019 00:22 by Warren3200gt.
- Oldjeep
21 May 2019 03:48Warren3200gt wrote: Why cant you just take the calliper off, put the wheel back in then put the calliper back on? You won't be juggling the weight of the wheel and trying to align the calliper and pads at the same time then.
That would be the way i did it when r/r my rear wheel. Can't imagine trying to do it with the caliper in place.
Chuck
81 KZ750 LTD
03 FZ1
www.oldjeep.com
81 KZ750 LTD
03 FZ1
www.oldjeep.com
- dpivas7
21 May 2019 10:28Warren3200gt wrote: Why cant you just take the calliper off, put the wheel back in then put the calliper back on? You won't be juggling the weight of the wheel and trying to align the calliper and pads at the same time then.
Because I was going by how the manual tells you to do it. I got the wheel back on with the caliper off (but with the brake line still attached) but then a pad fell out and now I can't get the pad back in.
21 May 2019 11:07
The caliper will close up a little after a while. I take a tire spoon and open them up just enough to fit the rotor. As you apply pressure it will slowly open back up.
The following user(s) said Thank You: Warren3200gt
- Warren3200gt
21 May 2019 11:40 - 21 May 2019 11:47
Open the calliper up with a tire spoon as Steve says, keeping an eye on the fluid level in the reservoir, fit the pads, open the calliper so its wide as the disc slip some cardboard between the pads to keep them in place, slip over the disc, once halfway on slide the cardboard out and push the calliper on and bolt it up, job done.
Last edit: 21 May 2019 11:47 by Warren3200gt.
