Is a 77 frame the same as a 83 frame?
- RobertPatrick77
27 Feb 2019 16:30
Did the frame of The KZ 650 change from 1977 to 1983? Or did they remain the same??.... I cannot find this answer anywhere.. please help!!
- Rockybalboba
Re: Is a 77 frame the same as a 83 frame?
27 Feb 2019 16:45
The following user(s) said Thank You: RobertPatrick77
27 Feb 2019 17:19
WHAT YEAR IS THAT SEAT? :lol: :lol: :lol:
- Rockybalboba
27 Feb 2019 17:30
Lmao, something my old man gave me, old, was on a horse drawn mower, so I would date it most likely pre 40s maybe lol
Far to wide, would of looked alright with stock tank. But not comfortable
27 Feb 2019 18:28
Different.
The 1977 KZ650-B1 frame was part number 32002-155.
The 1977 KZ650-C1 frame was part number 32002-1008.
The 1983 KZ650 H3 frame was part number 32002-1504.
- RobertPatrick77
27 Feb 2019 18:53 - 28 Feb 2019 03:39
Was looking for a hardtail weld on but only found one that is good for 81 to 83 i guess
Last edit: 28 Feb 2019 03:39 by RobertPatrick77.
28 Feb 2019 06:11 - 28 Feb 2019 06:18
Does the hardtail assy have measurements? how about a link. curious as to where it attaches.
I would compare the frame diagrams at Partzilla & frame pics on eebbaayy and compare them to yours.
If you can't find good pics of a 650-CSR frame, try the KZ750H Ltd as they are the same.
note: the 750-CSR is a Twin & that frame is completely different.
650-CSR frame: different steering head angle. different method of fuel tank attachment. I think the frame tubes for the seat are lower. no ducktail or seat cowling, so the rear of the frame is different. removable mufflers stays, instead of welded-on stays. I would guess the CSR fits around the engine the same, so the frames might be kind of similar or pretty much the same in that regard.
Last edit: 28 Feb 2019 06:18 by martin_csr.
- zed1015
28 Feb 2019 09:50
All the Z650's use the same basic "loop" around the engine with slight differences between models for body work , exhaust hangers etc and as mentioned lower seat rails for the ltd and revised head angle for the CSR.
A weld on hardtail should fit any year as you will be chopping of the rear of the frame anyway.
- RobertPatrick77
28 Feb 2019 14:26
Sounds like solid advice . looking at the photo now and it pretty much does away with most of the frame changes.. I contacted the seller and they contacted the manufacturer.. I should know tomorrow.
- zed1015
28 Feb 2019 15:28
That's more than a weld on hardtail.
That's pretty much two thirds of the frame.
With the amount of original frame gone i could make that fit anything.
28 Feb 2019 15:38
That frame looks mighty flimsy to me - single backbone. etc. I wouldn't want to ride a KZ650 with that frame, but I guess like many "custom" bikes it is only going to be shown rather than ridden it won't matter much. Ed
- RobertPatrick77
28 Feb 2019 16:20 - 28 Feb 2019 17:15
I plan on riding it.. and i live in a bad area for hard tails.. I found out with my last two bikes. maybe i should consider this. I trust the up right tube to hold it together. The last bike i had was a death machine, it was the worst ride i ever had.. but worth it when i hit smooth.. it let's you know when to slow down.. sometimes unexpectedly!
Last edit: 28 Feb 2019 17:15 by RobertPatrick77.
