Fork upgrade with emulators
  • waktaylor
  • waktaylor's Avatar
Re: Fork upgrade with emulators
21 Feb 2019 19:28
#799031
I recently installed racetech gold valves. Racetech gives preload and “tuning” starting point for each bike. Check out their site and read in their instructions.
I used their recommendations and it’s like night and day. I think I’m 7 turns in which is a tad hard so I’m gonna set them to 5 turns in and be done.
Forks have to be completely disassembled for the work that needs to be done.
  • gordone
  • gordone's Avatar Topic Author
21 Feb 2019 23:43
#799034
waktaylor wrote: I recently installed racetech gold valves. Racetech gives preload and “tuning” starting point for each bike. Check out their site and read in their instructions.
Thank you!
I think these must be a project for the next winter. So you have got a «new» bike now? :)
What about fine tuning do you need to completly dissamble the forks?
Project:
  • DoctoRot
  • DoctoRot's Avatar
22 Feb 2019 00:14 - 22 Feb 2019 00:15
#799035
you remove the fork cap and spring then fish out the emulator with a magnet. It can easily be done while one the bike. Race tech has pretty good instructions and tech support.
Last edit: 22 Feb 2019 00:15 by DoctoRot.
  • gordone
22 Feb 2019 01:05 - 22 Feb 2019 01:12
#799036
Perfect :)
Project:
Last edit: 22 Feb 2019 01:12 by gordone.
  • Nessism
  • Nessism's Avatar
  • Away
22 Feb 2019 05:25 - 22 Feb 2019 05:26
#799041
I put Racetech emulators in my 750 forks. As mentioned, the forks need to be removed but the project is not difficult. And since the forks will be off that's a good time to grease or replace the steering head bearings too.
I installed Sonic springs and I'd say the springs made a bigger difference than the emulators. The emulators are nice and all but I don't notice a huge difference between them and the stock setup. I installed them and never pulled them to fine tune though. Maybe I should? I'm reasonably happy with the front end performance so I didn't find the need to experiment much.
Last edit: 22 Feb 2019 05:26 by Nessism.
  • DoctoRot
  • DoctoRot's Avatar
22 Feb 2019 13:32
#799075
If you have clapped out old springs you're going to have a bad time.
  • waktaylor
27 Feb 2019 17:09
#799353
Sounds like you need to tune them. the dampening characteristics are gonna change in a very good way.
Did you leave the adjuster bolt alone? Mines are 7 turns in but they need to by 4 or 5 turns in instead.
  • CoreyClough
  • CoreyClough's Avatar
  • GPz550 Addiction
01 Mar 2019 04:33
#799438
I am running the Race Tech Gold Valves on my 85 GPz550, and love it. Previously I was running Progressive Suspension Springs only with the recommended oil level. Big difference in front end from then to now. Love it! Doing the Gold Valves, it disables the Anti-Dives. I still have them bolted on, but the brake lines to them are no longer there. Like that of the Ronco Grill, I set it and forget it. Been running this for a year now.
'85 GPz550(ZX550-A2)
  • gordone
01 Mar 2019 14:46
#799484
CoreyClough wrote: I am running the Race Tech Gold Valves on my 85 GPz550, and love it. Previously I was running Progressive Suspension Springs only with the recommended oil level. Big difference in front end from then to now. Love it! Doing the Gold Valves, it disables the Anti-Dives. I still have them bolted on, but the brake lines to them are no longer there. Like that of the Ronco Grill, I set it and forget it. Been running this for a year now.
Thank you for your input.
You have replaced the progressive spring to «normal» one?
Project:
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
03 Mar 2019 06:20
#799564
Besides the emulators a stiffer spring is a good idea. Also, dont forget about upgrading the shocks.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • gordone
03 Mar 2019 07:41
#799570
Kidkawie wrote: Besides the emulators a stiffer spring is a good idea. Also, dont forget about upgrading the shocks.
I have new shocks rear, what spring is best with emulator, not progressive?
Project:
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Mar 2019 08:25
#799575
I have progressives, emulators are next then a fork brace.
